2001.5 low mile Nogaro 6spd AWE stage 3 Audi S4, Ohlins, 355mm Brembos, reblt trans
Old May 15, 2015 | 08:00 PM
Calif_Kid's Avatar
Calif_Kid is infamous around these parts
Sold!!2001.5 low mi Nogaro 6spd AWE stg 3 Audi S4, Ohlins, 355mm Brembos, reblt trans
Year: 2001
Make: Audi
Model: S4
Price: $18200
Mileage: 67500
Color: Nogaro Blue
Location (State): CA
Transmission: Manual
Drivetrain: 4WD & AWD
If you’re looking for a low mileage Nogaro 6spd AWE stage 3 Audi S4 with rebuilt trans, OEM RS4 CF interior trim, Ohlin coilovers with 700F/800R spring rates, Brembo 355mm 4 piston front brakes with two piece rotors, 034 Motorsport 300mm rear brakes, 4:1 center diff, BBS CH wheels, and more, then I think you’ll like this car.
I’ve decided to sell my 2001.5 Nogaro 6 speed AWE stage 3 S4.I bought it in Oct 2006 with around 44K miles.It has 67.5k miles right now.It was originally featured in Eurotuner at http://www.awe-tuning.com/media/pdf/6_05_eurotuner.pdf and the ad from the previous owner is at http://www.audizine.com/forum/showthread.php/97278-2001-5-Nogaro-Black-CF-6spd-AWE-stage-3-Eurotuner-Feature.Per Carfax, I believe that I’m the fourth owner.Per the previous owner, the stage 3 kit was installed at approximately 20K miles.When I bought the car, it had Stasis Tracksport coilovers, but I sold those and bought Ohlin Motorsports coilovers from Stasis, plus added the 4:1 center differential mod.I also upgraded from Green top to Green Giant fuel injectors. I ran the car at various Audi Club and Nasa track events in 2007-2008, but I then bought a Honda Civic hatch full race car and saved the S4 for street driving only. I’ve always used Mobil1 0-40W oil, and made sure to warm up the engine oil before getting into boost, and cool it down afterwards. The car has always passed California Smog tests without any issues.
I want to disclose that I had one accident with the car – in Oct 2009 there was an animal on the freeway, and the bumper, radiator, A/C condenser, and subframe brace/rear cross support had to be replaced with 2Bennett Automotive in Davis CA doing the repair.
Why am I selling the car??Well, I’ve got a 2001 6-speed 2.7T A6 and a F150 truck, and with the Honda Civic hatch for track days, I decided to go ahead and sell the S4.I’m located in Sunnyvale, CA (zip 94087) with the price being 18.2K.
Color: Nogaro Blue Pearl Effect – some chips in the paint on the bumper and minor chips in the hood, plus under the fenders where they were rolled.
Interior: Onyx
Int. Trim: OEM RS4 Carbon fiber
Mileage: 67,XXX
VIN# WAURD68D81A134978
**Engine
  • AWE Tuning K04 Turbo Kit (including AWE K04 Fueling Kit with Green Giant fuel injectors)
  • Vast ported and polished ceramic coated exhaust manifolds – installed July 2008
  • AWE Manifolds will be included, but are cracked and need welding and recoating
  • AWE LW Flywheel
  • Samco TBB
  • AWE Intercoolers
  • AWE Drive Train Stabilizer Bar – standard mount is installed, but will include Energy Suspension mount
  • 034Motorsport poly front snub mount
  • 710n Diverter Valves
  • RS4 y-pipe from Europrice
  • GIAC 5 program handheld switcher - Stock/Pump/Race/Valet/Kill
  • Matrix 25row Oil Cooler – installed in July 2007 in preparation for running at the track
  • Air filter housing has the Darintake modification
  • EGTs – new EGTs were installed Feb 2009, but now using EGT deletes
  • Defoulers are currently installed
  • Extra M-box ECU will be included
  • New timing belt, water pump (with metal impeller), thermostat, and auxiliary water pump installed in July 2008 by 034 Motorsport
  • Motor mounts – new street density mounts installed by 034 Motorsport April 2008
  • New N75 valve installed in Oct 2014 as the boost was going higher than the normal 20-21psig on the street
  • New Mass Airflow Sensor installed Sept 2008
  • New Bosch F5DPOR spark plugs installed Jan 2015 at 67.1k miles
**Exhaust system
  • Stratmosphere Milltek Down Pipes with high flow cats
  • AWE Twin2 exhaust – bought new in Oct 2006
**Transmission/Driveline
  • 6spd manual transmission – rebuilt at 58K miles due to 1-2 collar lock up by Wicked Motorsports
  • Clutchmaster stg4 FX400 6-puck clutch plus new slave cylinder – also installed at 58K miles
  • Stasis 4:1 center differential installed by 034 Motorsport in July 2008
  • Aprikol rear diff mount with red (race) bushing – installed by 034 Motorsports April 2008
  • Trans mounts – new street density mounts installed by 034 Motorsports April 2008
  • CV boots – front right outer boot was replaced in Oct 2009, and front left inner and outer boots in Aug 2014.
  • JHM solid short throw shifter with solid linkage upgrade
**Suspension
  • Ohlin Motorsports coilovers with Hyperco 700 lb springs front & 800 lb rear springs – bought new and installed by Stasis in Dec 2006. Rear shocks changed to emulsion by Stasis in Aug 2009.
  • Neuspeed 19mm rear anti-sway bar with reinforcement brace – always left at full stiff on street and track
  • New front upper control arms installed at 46k miles in June 2007 by Burlingame Independent VW/Audi
**Brakes (front)
  • Brembo 355mm Gran Turismo 4 piston (40mm and 44mm) Big Brake Kit with two piece (355mmx32mm) rotors– installed new slotted rotor rings and hardware from Pure Motorsport in Feb 2009
  • Ferodo ds2500 brake pads for street. Also have Hawk Blue pads for cleaning and Carbotech XP10 pads for the track.
  • Stasis Engineering Wheel Studs
  • Motul RBF600 brake fluid (newly flushed)
**Brakes (rear)
  • 034 Motorsports 300mm (B7 S4) rear brakes with braided brake lines – installed by 034 Motorport in Oct 2009
**Wheels/Tires
  • BBS CH 18x8.5 with ET35 offset – the spare is also a BBS CH. One wheel has light curb rash.
  • Bridgestone Potenza RE-01R 235/40-18 tires with approximately 5-6/32nd’s of tread remaining
**Exterior
  • European Valeo Headlights (AWE)
  • RS4 mesh for Front Grill (AWE)
  • RS4 mesh for lower bumper with center bars deleted by 2Bennett Automotive – fog lights are currently not installed, but are in good condition and will be included
  • Brushed aluminum rs4 mirror housings are installed, plus will include the original Nogaro housings.
  • Rolled front fender lips plus plastic wheel well liners have been trimmed (ran 234/40-18 tires on the street and 245/34-18 tires at the track without rubbing)
  • Front windshield – new windshield installed March 2015 as old one had small light chips from the track
**Interior
  • OEM rs4 Carbon Fiber beltline trim including hazard, ashtray, and shifter surround
  • RS4 Shift ****
  • AWE Center Boost Gauge
  • Audi Winter Mats for rear
  • LI-S4s Valentine 1 remote display
  • Premium Package
  • Power Glass Sunroof
  • Homelink remote transmitter
  • Bose premium Sound System
  • Cold Weather package
  • Heated front seats
  • Expandable Ski/Storage Sack
  • No missing pixels in Center display
Maintenance – most of the maintenance was done by 034 Motorsport, but as their invoices listed the date, but not the mileage, I included the mileage at various dates below.
Mileage Date
43.9k 10/2006
45.8k 6/2007
48.8k 1/2008
50.0k 4/2008
51.6k 6/2008
52.5k 8/2008
57.1k 3/2009
58.2k 1/2010
63.0k 4/2012
66.3k 7/2014
67.4k 3/2015
Old May 16, 2015 | 05:57 PM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Nice looking S4 with the right mods. How did you do at Laguna? Glws
Old May 16, 2015 | 07:40 PM
Calif_Kid's Avatar
Etchhead - Thanks for the comment. I think that I ran with NCRC (Norcal Racing Club) at Laguna Seca in the S4, and ended up running a 1:49 as my fastest lap. The thing is, that I really wasn't driving the car very hard in the corners, as I wasn't sliding the car/tires at all.
In my Honda Civic hatch race car (shown below - basically setup for Nasa Honda Challenge H2 series with 180-185whp, 8500rpm, and 2500 lbs with 160lb driver), in the same timeframe, I ran a 1:52 lap, but that was without the rear wing. Recently, my lap time (with the wing) in the Civic was 1:47 with a passenger, and with a pro level driver and me as the passenger, the laptime was around 1:45, so I'm sure that the laptime with the S4 would be a good bit faster with a good driver pushing the car hard.
One nice thing, is that with the Twin2 exhaust plus exhaust elbows, hopefully the 90db sound limit won't be much of an issue for the S4 at Laguna. The S4 was fun to drive at Sonoma/Infineon plus Laguna with all of the power, torque, and traction for accelerating out of the slower corners (like turn 4 and 11 at Sonoma, and 6 and 11 at Laguna). - Jim
Old May 16, 2015 | 10:14 PM
Etchhead's Avatar
Nice! I was finally able to beat my 996tt Laguna time in the 997GT3 last month (1:40.2). I find with the noise restrictions and hills the quite HP is key, or the best exit speeds. My old S4 only had a Giac tune and was automatic but saw all of the cool builds with K04s. It's the RS build so no doubt safe and performance guaranteed.
I'm looking for a purpose built track car to replace the GT3... I think.
Old Aug 14, 2015 | 01:04 PM
Calif_Kid's Avatar
Lowering the asking price
A few people have been interested in the car, but no final deal yet. I'm lowering my asking price from 19K to 18.2K - Jim
Old Sep 17, 2015 | 01:42 AM
Calif_Kid's Avatar
Sold!!!
The car was sold today to a longtime Audi enthusiast in the northern SF Bay Area. Sad to see her go, but she is in good hands!! - Jim
STAGGERED M3
Sep 11, 2015 12:00 AM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
BauerR
Aug 22, 2015 09:54 AM
