BMW e46 M3 - 2001 LSB, Coupe, 6-Speed Manual - 41800 miles
Year: 2001
Make: BMW
Model: M3
Price: $1
Mileage: 41800
Color: Laguna Seca Blue
Location (State): NJ
Transmission: Manual
Drivetrain: Rear Wheel Drive
Basics
- 2001 BMW M3 Coupe 6MT
- Laguna Seca Blue/Gray
- 41,800 miles (I bought it with 27k)
- HK Sound, Moonroof, Power/Lumbar/Heated Seats
- Rain Sensor
- CD Player + IPod hook
- No evidence of track or winter/salt/snow (previous owners averaged 2.5k miles/year)
- I always garaged it and it seems to have been generally well-kept
- All keys (including valet), manuals, tools and window sticker
- Complete history for 2001 to 2009 and 2011 to current (a thick folder of service). Indication of previous owners having OCD.
- No accident history. I had lower portion of one of the doors repaired and resprayed after my motorcycle leaned and creased it. The front may have had a freshening respray when I got it, but since then has acquired a few chips. All parts look original so I think it was cosmetic.
While LSB, coupe and manual are highly desirable to the collector crowd, they do have a fetish for black interiors and slicktops. I get the top for track cars, but on the street, I personally enjoy both the light, airy interior and the tilt/slide/glass roof.
Mods/Additions
- Dinan Section 3 installed at Maximum PSI. An excellent condition stock exhaust will be included
- Autosolutions SSK 20%. Great improvement. I will include stock shifter and bushings but can't imagine anyone would want vague
- Off-road spec 35W halogen bulbs in low-beam, properly aimed
- Clutch stop, shortens travel, matches shifter
- OEM Front Strut Bar (01's didn't have it)
- Minor stuff like LED tails (non-OEM) (Stock tails included)
- Black grille and trim items (Stock chrome included)
Maintenance
- Valve Adjust done at 30k miles, most were in spec, visible part of engine super clean (pics available)
- Rod bearing recall done early on as well as many, many oil changes
- Airbag recall complete (passenger replaced, driver's was checked)
- Subframe inspected twice under previous owners at dealers, passed to their specs. I had it informally inspected at Maximum PSI at mid-30's mileage, he said it looked fine
- VANOS repair/rebuild at Maximum PSI using Beisan and Cryo (both broken hubs found)
- Plugs & Coils done recently at BMW specialist shop
- Moonroof shade track repaired by body shop
- Both door seals (large) replaced by body shop
- All fluids flushed under my ownership
- Michelin Pilot Super Sports, 80-90% in rear, 60% up front (will provide depth). Also fronts are XL, damned MPSS doesn't come in standard load for 225/45/18
- Driver's keyhole delete, color-matched
- Brakes original and vibration free
- No squeaks or sounds from the suspension
- Clutch strong and smooth, not abused
The Not-So-Perfect
- Wheels (original to the car) were refinished a couple of years ago, they are straight and look decent but not perfect (some peeling)
- One wheel has small curb rash (maybe two?)
- Minor hairline scratches on bumpers, very small
- Some scratches under front spoiler (on plastic) driveway/parking stops
- Driver's seat lumbar only works when seat folded forward (same for five years)
- A spill on front passenger footwell rug (bleach or paint?), mostly under the floormat
- Windows have tint from previous owner and the tint is slightly tired (not visible in pictures), I'm keeping it for protection, but a perfectionist might take off or replace
- Minor wear on driver's seat bolster
- Will need rear brake pads soon
Detailed Maintenance (with records)
1135mi - 1200mi service
- diff & gearbox fluids
- brake bolts recall
- front door adjust/lube, clutch stop, alarm
4975mi - brakes lubed for screech
- door panel & seal replaced for closing effort
- dimming mirror replaced
- oil & cabin air filter
- brake fluid
5260mi - 2 rear michelin pilot sport (flat)
13450mi - parcel shelf speaker replaced
- DME update
- parking brake adjust
13600mi - connecting rod recall
- oil & filter
- front brake disc rotors & pads replaced for warpage
- power steering pressure hose replaced for leak
18500mi - OBD communication/DME update
- HVAC, final stage resistor (FSU) replaced for erratic fan speed
18800mi - subframe (rear axle carrier) inspection
- rear diff fluid replaced (grinding noise while cornering SIB 33 01 02 (last service by first owner)
19400mi - subframe inspection (second owner, different dealer)
23950mi - oil & filter change
- air filter, cabin air filter
- brake fluid, L fog lamp (third owner)
24000mi - front & rear michelin pilot super sport
24500mi - stones removed from brake shields
25000mi - exhaust cam sensor & seal
26000mi - Bosch battery
26850mi - oil & filter change
- idler & tensioner pulleys replaced for noise
27800mi - 65W Osram bulbs (fourth owner - ME!)
- Dice Mediabridge
- black grille
- clear sidemarkers
- clutch stop
28100mi - valve adjustment & valve cover gasket (xxPowerx)
- front strut brace install
29800mi - passenger door seal replaced
- moonroof shade tracks (ECS Tuning kit + body shop)
31000mi - oil & filter change
- diff fluid
- gearbox fluid
- coolant flush
- Dinan exhaust install
31600mi - cabin air filter
- new floor mats
32000mi - LED tail lights
33700mi - Upgraded C300 VANOS exhaust hub
- Cam bolts, VANOS seals, gasket, cover & timing
- Beisan VANOS solenoid (broken tabs found)
34200mi - alignment
35000mi - front tire replaced (flat)
35300mi - oil & filter change
- fuel filter
- brake fluid
- hood emblem (stolen)
- horns replaced
36800mi - front tires replaced
37450mi - 6 ignition coils & spark plugs
- fuel filter
- deodorize HVAC system
37700mi - wheels refinished
37750mi - engine air & cabin air filter (self)
38250mi - Bosch battery (self)
38950mi - oil & filter change
- exhaust gaskets replaced
- Autosolutions 20% SSK Install
- power steering fluid flush
40200mi - 2 rear tires, michelin pilot super sport
40300mi - passenger airbag (Takata) recall at dealer, replaced
- power steering fluid leak found
40700mi - handbrake tightened
- power steering fluid leak fixed
40725mi - driver's door seal replaced (installed by body shop)
41350mi - driver's side fog light replaced (self)
41400mi - driver's airbag checked under recall at dealer, not replaced
The Number
Off the market
Added detailed maintenance history for which I have records. I will add pictures of manuals, keys, window sticker as well as the blemishes. Turns out the area of carpet discoloration is limited and pretty much hidden. Wheel edges have some imperfections. Will post those as well.
