2006 BMW M3 Alpine White / Black / 6-Speed / 59k Miles / PA 19008
Old Aug 19, 2018 | 11:13 AM
MJTSUB's Avatar
MJTSUB is infamous around these parts
Year: 2006
Make: BMW
Model: M3
Price: $34950
Mileage: 59323
Color: White
Location (State): PA
Transmission: Manual
Drivetrain: Rear Wheel Drive
CAR IS SOLD!!!
by https://www.flickr.com/photos/70138657@N05/, on Flickr
Hi Everyone! I have decided to put my 2006 BMW M3 up for sale. I am a longtime BMW enthusiast and BMW CCA Member for over 20 years. This is my second E46 M3 and these cars are absolutely amazing and so well balanced. Since purchasing the car I have spent a touch over 240 hours of extensive detailing, paint correction and part replacement. This car might just make Enthusiast Auto Group blush (No disrespect EAG J). This car is 100% turn key and needs nothing other than a new home, garage and driver.
This M3 is just about all stock and all original. You are looking at the last of the BMW M3 high revving normally aspirated straight 6 cylinder, 6- speed manual, front engine, rear drive, non-bloated analog experience. Simply put they aren’t making any more of these.
I have tried to itemize and present this car as perfectly clear and transparent as possible. PPI’s are welcome within a reasonable distance. I use Leading Edge Autosport which is located in West Chester PA 19382. Should you have any additional questions please don’t hesitate to contact me.
Onto the Videos and Photos!
497 Photos:
https://flic.kr/s/aHskDehiVz
• Exterior Walk Around Video:
• Engine Bay Walk Around Video:
• Driver Side Front Interior Walk Around Video:
• Passenger Side Front Interior Walk Around Video:
• Driver Side Rear Interior Walk Around Video:
• Passenger Side Rear Interior Walk Around Video:
• Trunk Walk Around Video:
Basic Information About the Car:
• 2006 BMW M3
• VIN: WBSBL93446PN63998
• Build Date: 9/22/2005
• Original MSRP: $59,320 (Including Destination and Gas Guzzler Tax)
• Alpine White / Black Nappa Leather / Aluminum Interior Trim
• Transmission: 6-Speed Manual
• Mileage: 59,323 (This is parked in my climate-controlled garage on a battery tender so mileage won’t change much if it all.)
Packages:
ZPP - Premium Package
403 – Power Glass Moonroof
459 – Power Front Seats w/Memory
490 – Power Adjustable Seat Back Width and Lumbar Support
639 – BMW Assist
N5-- - Nappa Leather
ZCW - Cold Weather Package
464 – Ski Bag
494 – Heated Seats
502 – Headlight Washers
Factory Options:
415 – Power Rear Sunshade
522 – Xenon Headlights
609 – On-Board Navigation
674 – Harman/Kardon Sound System
792 – 19” M Double Spoke Forged and Polished Wheels Style 67M
Ownership History:
Original Owner – 11/17/05 – 3/7/08
0 – 25,148 Miles
New Jersey
2ndOwner – 3/7/08 – 1/20/09
25,148 - 36,602 Miles
New York
3rdOwner – 2/23/09 – 2/2/18
36,602 – 58,934 Miles
North Carolina
4thOwner – 4/4/18 – 4/15/18
58,934 – 58,960 Miles
Florida
5thOwner – 4/15/18 to Present Date
58,960 – Current (59,202 Miles)
Pennsylvania
Maintenance History:
11/18/05 – 1,127 miles:
1,200 mile service
6/5/06 – 7,168 miles:
Adjust Rear Bumper Assembly
10/3/06 11,523 miles:
Differential Fluid Change
Oil Change
Microfilter Replacement
10/18/07 23,996 miles:
Inspection 1
Valve Adjustment
Profile Gasket Replaced
Spark Plug Rubber Seals Replaced
Oil Change
Brake Fluid Flush
Wiper Blade Replacement
Washer Fluid Added
11/7/07 25,146 miles:
Interior Rear-View Mirror Replaced Under Warranty
10/17/08 34,491 miles:
Bluetooth Telephone TCU/MULF Combox Occasional Failing - Reset TCU Module
10/20/08 34,591miles:
Oil Change
Microfilter Replaced
Washer Fluid Added
12/3/08 36,452 miles:
New Battery Installed
10/8/09 47,926 miles:
Inspection 2
Valve Adjustment
Oil Change
Brake Fluid Flush
Differential Fluid Flush
Transmission Fluid Flush
Driver Side Shock Tower Reinforcement Plate Replaced
Driver Side Indicator Replaced
10/8/09 47,926 Miles:
Recall B122208 DME Control Module Reprogram
2/7/18 58,854 Miles:
Oil Change
Accessory Drive Belts Replaced
6/7/18 59,085 Miles:
BMW OEM CSL Front 19x8.5 ET 44 and ZCP Rear 19x9.5 ET27 wheels and Michelin Pilot Sport 4S Tires Mounted and Balanced
245/35-19XL (93Y) Date Code 0917
275/30-19XL (96Y) Date Code 5117
Oil Filter and Fluid Change (Castrol Edge 10W-60)
Subframe Inspection
Fuel Filter Replacement
6/22/18 59,102 Miles:
Front Bumper Repaint
Front Hood Repaint
Front Hood Dent Removal
Rear Bumper and Valance Repaint
8/9/18 59,191 Miles:
Factory Recall Driver and Passenger Airbag Replacement
Passenger Dash Trim Replaced
Brand New Passenger Side OEM “A” Pillar Supplied from Otto’s BMW due to mistake during the replacement of the factory air bag recall. Small blemish as shown in photos.
10/29/18 59,323 Miles:
New OEM alternator installed
Subframe Inspection (No cracks or issues)
Common/Typical Questions and Answers Associated with any E46 M3 and S54:
• Is the Subframe cracked, torn, bent or showing signs of cracking?
No and a recent inspection on 6/7/18 and 117 miles ago with paperwork supports that. Underside photos and photos of the rear floor have been provided as well.
• Has the Vanos been overhauled or rebuilt?
No to the best of my knowledge everything is still original and OEM. A scan for any fault codes was performed on 6/7/18 and 117 miles ago with no codes showing..
• Have the rod bearings been replaced?
No this is a later production car that did not have the rod bearing failures of the early production year M3’s. The Blackstone oil analysis also shows a very low Lead and Copper value which supports good rod bearing health without opening the motor up and removing them to inspect.
• Does the car need a Valve Adjustment?
No this S54 motor has had a valve adjustment performed twice. First time was by BMW of Freehold at 23,996 miles on 10/18/07 and the second time was by West German BMW at 47,926 miles on 10/8/09.
• Has any of the cooling system been replaced?
No it appears all original and I don’t have any records nor does the CarFax show any service of anything being replaced or repaired.
• Are there any fluid leaks?
No as of 6/7/18 and 117 miles ago there are no signs of any fluid leaks on the motor, transmission, differential, brake lines, cooling system components, A/C lines and compressor, power steering lines and pump and reservoir, washer fluid tank and lines.
• Do the window regulators work?
Yes, the front windows both roll up and down all the way, one touch feature works, and the auto window drop/roll-up when opening and closing the doors works. Rear windows move out and close as they should as well. Sunroof tilt/close/open and one touch features work as well.
• Are there any pixels out in the dash or Navigation screen?
No all the dash lights work perfect and the navigation screen was replaced with an OEM Sharp 6.5” LQ065T9BR54U screen. There are no scratches or blemishes on the monitor.
• Has the factory Takata air-bag recall been done?
Yes on 8/9/18 at 59,191 the driver and passenger front air bag recall was performed and a double check that any and all other open recalls or service bulletins have been performed while at Otto’s BMW in West Chester PA.
Other Main Questions and Answers:
• Are there any accidents, thefts, or other issues with the CarFax and Title?
No, the CarFax and Pennsylvania title are clean and the car has not been involved in any accidents, thefts, floods, repossessions or anything that would negatively impact the car. All the bodywork, bumpers, glass and trim are original.
• Is there any paintwork done to the car?
Yes, in an effort to make the car perfect I elected to have the front bumper, trim pieces under the headlights, hood and rear bumper painted. I have included pictures showing the condition of those parts prior to paint to help explain why I made this decision as well as show that paintwork was not required do to extensive damage or accidents.
The front bumper had a clear bra on it that was applied at some point after it was new. I removed it as it was yellow and faded and in poor condition. There was rock chips and a small scrape on the bottom of the bumper that could not be corrected. Additionally, the installer of the clear bra cut and trimmed it directly on the paint leaving permanent cut marks on the front bumper. Lastly there were two holes drilled in the front bumper for the use of the OEM front license plate holder.
The front hood was repainted for two reasons. There was a dent to the left of the passenger side kidney grille as shown in photos that could not be corrected through paint-less dent removal. Additionally, there was a scratch down to the metal in-between the kidney grilles. Lastly just like the front bumper the clear bra was trimmed and cut on the clear coat and those marks could not be wet sanded and paint corrected to make the hood look right.
The front trim pieces under the headlights were resprayed to remove rock chips and since the bumper and hood were being painted it made sense to do those two pieces at the same time.
The rear bumper on the passenger side had some spider cracks and clear coat fade. Oddly enough it was just on the passenger side and not both sides. Again, in an effort to make the car look perfect the rear bumper was resprayed and the valance as well to make that whole area look perfect.
Paint match is perfect and there are no odd drip marks or corrections needed.
• Do you have the title and is the title clean?
Yes, I have a clean title issued from Pennsylvania in my possession with no liens or issues. It is in hand ready to sign over to the next owner.
• You mentioned you have refreshed the car to make it look perfect and brand new. What have you done to refresh the car during your ownership?
All parts are brand new OEM unless otherwise noted. All of these parts have less than 90 miles of use:
Refinish Front Bumper
Refinish Front Hood
Refinish Headlight Trim Pieces
Refinish Rear Bumper and Valance
Lower Center Bumper Mesh Grille
Center Hood Grille
Front and Rear BMW Roundel Badges
Kidney Grilles (Both Sides)
Side Gills (Both Sides)
M3 Badges for Side Gills (Both Sides)
Side Indicators (Both Sides)
Rear M3 Badge (Included but not installed)
“M” Emblem for Engine Cover
Micro Filter Replacement
Micro Filter Cover
Engine Air Filter
Washer Nozzles
Hood Gas Struts (Stabilus)
Trunk Gas Struts (Stabilus)
Headlight Covers
Headlight Gaskets
Lower Headlight Trim Gasket
Fog Light Housings
Fog Light Covers
Windshield Cowl Trim
Driver and Passenger Wiper Arm
Wiper Arm Bolt Plastic Cover
Wiper Blades (Bosch Icon)
M3 Driver and Passenger Side Sill Plate
Shadow Line Trim (This includes the driver and passenger side door, driver and passenger lower rear window area, vertical trim on both rear windows, and the large trim piece that goes from the A pillar to the C pillar which houses the rear window seals)
Battery
Rear License Plate Bracket
Clutch and Brake Pedal Covers
Accelerator Pedal Assembly
Shift **** and Boot
E-Brake Boot
Center Console Euro Storage Section
Driver and Passenger “B” Pillar Covers (Passenger Side A Pillar Included)
Third Brake Light Headliner Cover
M3 Floor Mats
M3 Trunk Mat
19 x 8.5 ET44 CSL Wheels
19 x 9.2 ET27 ZCP Wheels
BMW Roundel Center Caps
Michelin Pilot Sport 4S Tires 245 Front / 275 Rear
Front and Rear Brake Rotors
StopTech Front and Rear Brake Pads
Aftermarket Parts:
BimmerWorld 10mm Spacers on Both Front and Rear Axles w/Extended 31mm Shaft Length Wheel Bolts
BavSound Stage 1 Speaker Upgrade
-Replaces all the factory speakers except the rear subwoofers with plug and play connections. No drilling or splicing etc. Original OEM Speakers still included and I have the boxes for the BavSound Speakers as well.
Bimmian Painted Front Bumper Reflectors. I do not have the original OEM amber reflectors.
Headphone 3.5mm cable and Apple Lightning adapter to OEM Aux Headunit Input. This allows you to plug your iPhone or any device using a 3.5mm headphone jack to playback music through the factory system. This is reversible back to stock however a hole was drilled in the drop-in ash tray part to allow for the headphone cable to pass through.
Keys / Books / Manuals / Records:
I have both master keys but I do not have the plastic valet key.
I have all the manuals and books in the leather BMW case.
I have all the records dating back since new but I do not have much paper documentation other than what the CarFax provides during owner #3’s time frame. Mileage didn’t change much during their ownership but none the less I don’t have much in my possession.
I have the original window sticker which is laminated as shown in the photos.
Extras:
I have the original 19” Style 67 Forged Polished Double Spoke Wheels. They do have new center caps and “M” Stickers. I currently have them sitting in the CSL/ZCP Boxes. There are no bends or cracks and hardly any curb rash but I would rate them a 7/10 only because I am more than super picky.
Oil Change Kit - I will include 6 bottles of Castrol Edge 10W-60 oil, a Mahle Oil Filter, Oil Drain Plug and Crush Washer.
OEM “A” Pillar Cover (As stated earlier the dealership nicked the original one that is still in place and they supplied a new piece)
Trunk OEM M3 Badge
Detailing:
From start to finish this car has had the following products used on it to bring it to the condition you see in the videos and photos:
Chemical Guys Black Clay Bar / with Chemical Guys Luber Spray
Chemical Guys Blue Medium Clay Bar / with Chemical Guys Luber Spray
Sonax Profiline Cutmax
Sonax Profiline EX 04-06
Wolfgang Tire Dressing
Chemical Guys Metal Polish
Meguiar’s Clear Plastic Cleaner and Polish
CarPro Glass Polish and Cleaner
CarPro Reload Spray
303 Protectant Spray
Gummi Pflege Stift Rubber Care
Leatherique Cleaner
Leatherique Rejuvenator
CQuartz DLUX Plastic and Wheel Ceramic Coating
Wolfgang Uber Ceramic Coating
Rupes Polisher
Lake Country Pads – Orange/Blue/Black
Exterior Paint is ceramic coated via Wolfgang products. The wheels are ceramic coated via C-Quartz.
Production Number:
Some people like to know the production numbers of the car so here they are:
1 of 1,851 for the North American market in this color combo with manual transmission
1 of 2,397 in the world in this color combo with manual transmissions
Shipping If Required:
• I am happy to assist with shipping. Shipping costs are your responsibility and I will make myself available to meet any transport company at my zip code of 19008. I have used Intercede Transport Group, and U-Ship in the past with great success. I would strongly encourage that if you chose to ship that you move this car in an enclosed trailer. This car is spotless and perfect.
Terms of Sale:
• Price: $34,950.00
• Payment terms: Cash or Direct Wire Transfer Only (My car and title doesn’t leave my garage until the funds are moved into my account or cash is placed in my hand. Not trying to sound harsh but I will not lose the car or title to any fraud like activity. I am happy to provide references prior or during sale to help anyone.)
Contact Information:
Email:mjtsub@yahoo.com
Text/Call: (610) 283-6898
Old Aug 19, 2018 | 01:42 PM
GT3 Chuck's Avatar
Administrator
Please post all your photos here as required...no links...thanks
Old Aug 19, 2018 | 01:55 PM
jpetro1010's Avatar
jpetro1010 is infamous around these parts
Wow, I love the e46. Super clean car, GLWS!
Old Aug 20, 2018 | 11:52 AM
Myclue's Avatar
Myclue is a jewel in the roughMyclue is a jewel in the roughMyclue is a jewel in the roughMyclue is a jewel in the rough
I think this is the most detailed FS thread I have seen on 6spd so far
Old Aug 30, 2018 | 07:40 PM
MJTSUB's Avatar
Thank you! Spent a good bit of time putting it all together. It is such a great car to drive and look at.
Old Sep 16, 2018 | 06:10 PM
MJTSUB's Avatar
Bump!
Old Oct 14, 2018 | 06:24 PM
MJTSUB's Avatar
All PM's have been reply'd to.
Old Oct 31, 2018 | 06:58 PM
MJTSUB's Avatar
Bump!
New alternator installed on Monday due to a bad diode.
Subframe inspection done again with no stress cracks or issues found.
Old Nov 15, 2018 | 01:07 PM
MJTSUB's Avatar
Bump! Some people have asked about financing and I have had great success with Lightstream in the past.
Old Nov 15, 2018 | 07:25 PM
BillLee's Avatar
BillLee is infamous around these parts
Wow, i can't believe this hasn't sold yet. Very well taken care of and documented.
Old Dec 14, 2018 | 09:04 PM
MJTSUB's Avatar
Thanks....Still available!
Old Dec 22, 2018 | 12:44 PM
MJTSUB's Avatar
M3 is SOLD!! Thanks everyone!!
Global Autosports
Sep 19, 2012 08:31 PM
