3000GT VR4 Spyder 540AWHP
Year: 1995
Make: Mitsubishi
Model: 3000GT
Price: $34999
Mileage: 58000
Color: Red
Location (State): IL
Transmission: Manual
Drivetrain: 4WD & AWD
RARE 1995 3000GT Mitsubishi 3000GT VR4 Spyder -541 AWHP 509 Torque!
Walk around video: Please check on ebay
Wifi Hardtop going up and down: Please check on ebay.
OVER $40k in the build with receipts/records and pictures for documentation! Less than 2,500 miles on the build! Show room quality and properly built! I detail the car after every time I drive it, yes even to the gas station. I keep my Spyder stored in the garage under a car cover. I am selling my car because my wife and I are expecting next year. Here is a short list of upgrades ?Turbos - DR750 and ported (Tuned to run on E85, 93, or blend mix automatically) 272 3SX Cams
6G72 Spring and Retainer Kit
Ported Heads
1000cc Fuel Injectors - Injector Dynamics
BC BR Coilovers
Custom Quad Exhaust
3SX Rear Cat Delete Pipe
AWD Carrier Bearing
AWD Rear Transfer Case Seal
AWD Front Transfer Case Seal
Walbro 416 Fuel Pump
Front/Rear Oxygen Sensors
Turbo Oil Pan
Gates Racing Timing Belt
Spark Plugs - NGK Copper
IPS Shorty Downpipe with test pipe
AEM Version 2
AEM Boost Control Solenoid Kit
Southbend Stage 3 Daily Clutch
EGR block off plate
IPS Intercooler Kit
120k maintenance
Timing Belt Tensioner
Timing Belt Tensioner Pulley
Water Pump
Idler Pulley
Timing Belt
Alternator Belt
Alternator Idler Pulley
Power Steering Tensioner Pulley
Power Steering Belt
Fly Wheel
Oil Pump & Filter
Battery
Fuel Pressure Regulator
Fuel Pump
Fuel Pump Hat
HKS Universal SSQV4 Blow off valve
Rubber Engine Mounts
Big Bore Lifters
Dr Weldin Wastegates
Power Coat Valve Cover Red, polish letters
Polish Plenum & Port
Mishimoto Aluminum Radiator ? polished
Power Coat Intercooler & bottom 2 pipes for sleeper look
IPS TD04 Intake Pipes
K&N Air Filters for Intake Pipes
MSD Spark Plug Wires
Samco Radiator Hoses
GM E85 Flex Sensor Composition Sensor (Short Tube) and Sensor Harness
GM Solenoid
Ceramic heat coat exhaust manifolds
HKS Twin Power DLI
Throttle Body upgraded and polished
AEM Wideband
AEM Serial Data-Stream
AEM Boost Gauge
Vifa 2" Speakers
Slotted Rotors
Brake Caliper Kit and painted
Braded Fuel Lines
Powder Coated Brake Calipers
Turbo Complete Gasket Kit
Billet Fuel RailsTires/Rims in excellent shape and have around 2,500 miles WiFi- JNS Remote & Top Link, push a button to make the hardtop go up and down, very cool! I have over 120 pictures of the build from start to end plus 15 pages with receipts of every part, etc..please feel free to ask questions.Title in hand!
Ported Heads
BC BR Coilovers
Custom Quad Exhaust
AWD Carrier Bearing
Turbo Oil Pan
AEM Version 2
EGR block off plate
IPS Intercooler Kit
120k maintenance
Water Pump
Idler Pulley
Timing Belt
Alternator Belt
Power Steering Belt
Fly Wheel
Oil Pump & Filter
Battery
Fuel Pump
Fuel Pump Hat
Big Bore Lifters
GM Solenoid
HKS Twin Power DLI
AEM Wideband
AEM Boost Gauge
Vifa 2" Speakers
Slotted Rotors
Braded Fuel Lines
EagleTime
12-23-2015 06:13 PM
