1995 Toyota Supra TT 6 speed
Year: 1995
Make: Toyota
Model: Supra
Price: $85000
Mileage: 147000
Color: Black
Location (State): FL
Transmission: Manual
Drivetrain: Rear Wheel Drive
JT2JA82J7S0027116
factory v160 6spd car
147k on the body and about 5k miles on the build.
Every vin sticker is present.
Car has no rust and clean carfax/title and most importantly cold A/c
Following was done at 142k miles (have receipts for most of this)
-OEM piston rings
-OEM rod bearings
-OEM main bearings
-OEM timing tensioner
-OEM headgasket
-OEM thermostat
-OEM oil pump
-OEM water pump -
-Gates Blue RPM timing belt
-ARP headstufs
-AEM map sensor
-Aem V2 ecu
-1650 cc fic injectors
-Twin walbro 450 fuel pumps
-Hks 272 cams
-Hks cam gears
-Brian Crower Valve springs, retainers, and valves.
-PHR billet tensioner bracket
-Fluidine harmonic balancer
-TRD strut bar
-Fluidline Aluminum radiator
-Hallman boost controller
-ETS 4inch intercooler
-Spec twin disk clutch
-Aem wide band gauge
-Big oil cooler
-Lots of an lines routing everything from the idle air control valve to the catch can to the whole fuel system
-Twin Garret gt3076r turbos
-Custom Downpipes
-Custom turbo manifold
-Hks super dragger exhaust
-Tial 60mm waste gate
-Tial Blow off valve
-Aeromotive fuel pressure regulator
At 147k miles
-Powder coated all 4 calipers with all fresh OEM rebuild kits
-Steel braided lines
-Stop tech slotted rotors
-Ebc yellow pads
-New master cylinder (1998 style has no extra port for the trac pump)
-New OEM fan shroud
-Refinished oem wheels
-Sony headunit with bluetooth/carplay
-New OEM 98 headlights
-New aftermarket floormats. (Have 3 oem as well)
-Cluster capacitors rebuilt and LED added
-PHR fuel sending unit
-BC coilovers
-Redline fluids for trans/diff, vr1 for engine -Alignment
-Hood was repainted for rock chips
Dyno tuned by trilogy performance 582whp/489wtq @20 psi on very conservative tune @98 degrees air temp. 720+ on e85.
Price $85000
Located in naples FL
I also have some spare parts which can be added to the car. Aftermarket intake manifold, drag wheel/tire setup, stock 95 lights, various other stock parts. I am sure i am forgetting a bunch of small things but this should cover most of it
Creatre
Jun 7, 2020 07:02 PM
rennteche55
Mar 2, 2020 10:50 AM
vman932
Jun 4, 2017 12:31 PM
