WTB: 2006 Balloon White Gallardo SE (6-speed manual only)
Old Apr 18, 2007 | 12:28 AM
  #31
jrloM3's Avatar
jrloM3 is infamous around these parts
rick, where you at? you're car is waiting for you, and it's local! man, let me know if you decide to pull the trigger.
Old Apr 18, 2007 | 02:03 PM
  #32
s4play's Avatar
s4play has a spectacular aura abouts4play has a spectacular aura abouts4play has a spectacular aura about
I just heard that this white gallardo "may" be a gray market car so going to do some more homework on the history behind it.
Anyone have more info on the previous owners, dealer told me there were 2 previous owners and the 2nd owner bought it from Enigma and sold it back after only driving it like 400 miles?
thanks
rick
Old Apr 18, 2007 | 02:17 PM
  #33
JJB's Avatar
JJB
JJB is infamous around these parts
I don't think that it has Nav
Every 2006+ Gallardo has the multimedia screen and they will ask for you to insert the navigation disc when the nav button is pressed. The fact that they do not appear to have the disc and cannot show the actual map that should display if the disc is inserted tells me that they might be making an assumption that it is equipped with nav. I hear that often..."it has the screen so it must have nav..." Not true. I also noticed that their Dupont ad lists the car as an automatic when it is clearly an e-gear. Careless mistakes like these always make me suspect.
Get the VIN and that will answer your question about whether or not it is a US car.
JJB
Old Apr 18, 2007 | 02:21 PM
  #34
s4play's Avatar
This was taken directly from my source:
"Grey markey cars won't show up on Carfax, so even if you run the VIN, it's not going to pull the car...very possible the car was hit badly and repaired."
thanks for the NAVI note as well, I didn't bother to check if it has Daytime running lights since that's another clue it's not a US car.
rick
Old Apr 18, 2007 | 03:31 PM
  #35
Paul N's Avatar
Paul N has a spectacular aura aboutPaul N has a spectacular aura about
Have a dealer run the VIN for you. Service records, etc...
Good Luck
GrantRR
Jun 28, 2018 03:33 PM
RallyBird
Oct 7, 2015 01:20 PM
pshep138
Sep 1, 2015 09:45 AM
nal991
Aug 24, 2015 04:39 PM
