WTB 18mm spacers + bolts-- 996 Turbo
Unfortunately, 18mm are prob going to be special order.
GL finding a set.
What Coilovers did you go with?
GL finding a set.
NO IT DOES NOT UNLESS THEY ARE ADAPTERS THAT USE YOUR STOCK BOLTS TO MOUNT TO THE CAR FIRST!!
If you add spacers you will need longer bolts. I have 15mm and bolts if interested.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
You can get both from www.radusadirect.com , H&R also make 18's an can be had from our sponsors, Vivid for example. I was also able to get longer bolts from Vivid a while back to..
Anyone know what the minimum offset you can get away with is? I have a set of wheels that is sized for a 997 (62mm offset). I was thinking of getting 21 or 25mm wheel spacers from Boothe. Just curious.
FVD has a set of 18 mm spacers for your application. I know from first hand experience that the quality of these spacers is top notch. Also, the appropriate lugs bolts are included in the price as well. www.fvd.us
50 mm is about the max for a C2 so you dont want a spacer thicker than 12mm
The 17mm porsche tequipment ones have built in long studs and mount with your stock lug bolts. If you ask me that's preferred to messing with longer bolts, been there, done that.
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
