WTB: Wheel spacers for 997
I have a 997S with stock lobster claws. The car has 5 mm spacers all the way around but I would like to try something more aggressive. Preferably 7 mm front and 15 rear. Need the bolts too. Not sure I want to go this route so 'pre-owned' seems best. Hopefully one of you folks have an unused set taking up space in your garage.
Thanks,
Thanks,
Going from 5mm to 7mm is not aggressive - you probably won't be able to tell the difference. You will be able to see the difference between 5mm and 15mm though. If you have 5mm spacers already you should have bolts long enough for 7mm spacers...so it looks like your search would be for the 15mm + bolts. Good luck.
I assume you're commenting on the front. That is, just leave the 5's in the front, and focus on the 15's for the rear? If that's what you meant, thanks for the tip. I'll certainly try that first. Thanks.
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
PelicanParts.com
997 Vendor Classifieds
Aug 18, 2015 03:39 PM
