*******Big Brake Kits, Rotors, and Pads********
Old Nov 16, 2010 | 11:53 AM
PFC Brakes's Avatar
PFC Brakes is infamous around these parts
Category: Brakes
Price: $0
Private or Vendor Listing: Vendor Listing
Part fits: Porsche 911 997 Turbo, Porsche 911 997 Non-Turbo, Porsche 911 996 Turbo, Porsche 911 996 Non-Turbo, Porsche Cayenne, Porsche Boxter/Cayman, Porsche Panamera, Older Porsche, Ferrari, Lamborghini, Maserati, Aston Martin, Bentley, Nissan GTR, American vehicles, Other
Location (State): SC
Item Condition: Brand New
WHAT MAKES PFC BETTER?
Data Acquisition proves that PFC’s calipers are lighter, stiffer, cooler, and quicker than any other.
PFC applies championship-winning race technology to the design and manufacturing of these high-performance calipers to give you a brake system that is track-worthy.
Stiffer, more responsive, and quicker modulating system that not only provides better drivability and handling, but also improved ABS response.
LIGHTER
Innovative FEA optimized design for lightest total corner package.
STIFFER
Monobloc design increases stiffness which allows for better pedal response, more control, zero vibration, and quicker release time.
COOLER
Patented rocket nozzle insulators and superior piston caps reduce caliper temperature, increasing stiffness and reducing drag.
ZERO DRAGTM
PFC’s advanced caliper design reduces drag to zero allowing the brake system to deliver maximum stopping power, faster transition time, and quicker pedal response.
IT’S QUICKER.
It’s simple. Eliminate drag in the braking transition, so you can power through the corner, with nothing holding you back. Where other calipers can rob you of valuable horsepower, Zero Drag Calipers ensure you maintain maximum horsepower for increased power and faster lap times.
BENEFITS
Forged from aluminum, PFC’s Monobloc calipers are incredibly lightweight and have superior stiffness for quicker actuation, increased pedal response, less pedal travel, and decreased drag.
• No Vibration, Pulsation, or Judder
• Firmer Pedal
• Zero Fade
• Unsurpassed Modulation Characteristics
• Dramatically Improved ABS response
• Robust Race Design for minimal maintenance
• Longer Pad and Disc Life
• No Dust
• No Noise
• Improved Tire Adhesion with Zero Drag (patented)
• Improved Fuel Mileage
*AVAILABLE IN CUSTOM COLORS
TECHNOLOGY
HOW IS PFC DIFFERENT?
RACE-INSPIRED RADIAL MOUNT
Improves torque takeout, allowing your car to optimize every ounce of horsepower and deliver more power at the wheel end.
PFC’s PATENTED PISTON HEAT CAPS
Allow the caliper to achieve the coolest running temperatures—up to 50-100°F— which further increases stiffness and decreases drag.
FORGED MONOBLOC MULTIPAD CALIPER
- High-Temperature Aluminum alloy provides high temperature strength at extreme conditions for improved stiffness and decreased drag
- Robust race design reduces maintenance
- Patented piston heat cap technology prevents heat transfer allowing the brake and fluid to run cooler
- FEA Shape Optimization to reduce weight and improves stiffness
ZERO DRAGTM TECHNOLOGY
- Patented Pad Retraction System eliminates brake drag allowing for more power at the wheel end and quicker release and control
- Self-adjusting collars allow the pads to consistently pull back from the disc providing free running clearance under all conditions
- Reduced Pad Wear
From the TRACK to the STREET
PFC Street Rotors are RACE-WORTHY.
PFC’s street upgrade rotors are made using the same materials and processes as our championship-winning race rotors.
From design to raw material to final product, PFC’s street rotors are developed with the same passion and technology as our race rotors so you can experience performance that’s race-worthy.
THE PERFORMANCE…
• Lightest Design
• Longest-Lasting
• More Stopping Power
• Most Consistent
• Best Cooling
…IS IN THE DETAILS
• FEA Designed Thermal Capacity
• High Carbon Alloy with Molybdenum and Copper
• Vanes turned OD and ID
• More Consistent Microstructure
• Patented Feed Forward Control Machining Process
PFC has spared no effort in making sure that each PFC rotor is the best rotor you can buy. Take your vehicle to the next level. GIDDY UP.
RACE-WORTHY.
WHAT ARE THE BENEFITS?
BETTER DRIVABILITY.
• More Bite
• Better Release Control
• Increased Pedal Response
• Increased Corner Speed
BETTER PERFORMANCE.
No Judder, No Vibration, and No Distortion, delivering Quicker, Smoother Stops.
ZERO VIBRATION
• By eliminating vibration and drag the disc reduces the extraneous forces into the tire increasing the available grip.
LOWEST RUNNING TEMPERATURES
• Disc Temperature is reduced by the effective release of hot wear debris.
MINIMIZED THERMAL CRACKING
REDUCED THERMAL DISTORTION
PFC’s Finite Element Analysis to assure the lowest thermal distortion
PFC’s patented and trademarked slot patterns improve bite and are run cooler
QUICKER LAP TIMES.
PFC’S UNIQUE TECHNOLOGY
INNOVATIVE DESIGN ENGINEERING.
• Extensive FEA analysis
• Lightest Design
• Best Cooling
• Reduced Distortion
• Zero Drag
MOST ADVANCED MACHINING EQUIPMENT IN THE WORLD
Highest precision and tightest tolerance machining in the world……
so there is no doubt that your car is racing with the most capable disc in the world.
• Patented Feed Forward Laser Vision Measurement Control
• 100% measured and inspected
HEAT-TREATMENT
Eliminates residual stresses and results in a totally stable disc that will never warp.
MACHINED AT WORLD’S MOST CAPABLE TURNING CENTERS
100% LASER VISION INSPECTED
Results in perfect dynamic and thermal balance with absolutely no balance cuts or weights.
WHAT ARE THEY MADE OF?
EXCLUSIVE HIGH STRENGTH METALLURGY.
Ensures thermal stability and optimized friction characteristics, and excellent durability.
• Increased Carbon
• Alloyed with Molybdenum and Copper
• Consistent and uniform microstructure
• Aircraft quality furnace heat treatment
Brake Kits prices start out at $1,775 a small price to pay for race proven technology. Your not buying a off the shelf blanket kit like other brake manufactures. This is designed to fit your particular chassis.
Contact me directly for pricing and any other questions.
Old Nov 16, 2010 | 05:32 PM
PFC Brakes's Avatar
Bump
Old Nov 17, 2010 | 05:45 AM
ALE-SUPERBIKE's Avatar
ALE-SUPERBIKE is infamous around these parts
For 996 vc2 what the diametre front ?
Old Nov 17, 2010 | 06:24 AM
PFC Brakes's Avatar
The diameter is 318mm on our 2 piece replacement rotor that utilizes the factory caliper.
The big brake kit we offer that utilizes our 4 piston monobloc caliper, the front diameter we can engineer a 355 – 373mm rotor up front just depending on big you would like to go. Wheel size would play a key factor in this.
Old Nov 17, 2010 | 01:27 PM
You can have discs 330 / 340 with a thickness of 28 to 30 mm to be used on the original clip ?
Old Nov 19, 2010 | 07:35 AM
PFC Brakes's Avatar
No it just cant be done there isn't enough clearance but i do sell nice bbk for your car I have a group buy on them right now.
Old Nov 20, 2010 | 06:59 AM
TD997TT's Avatar
TD997TT is infamous around these parts
any kit for 997TT? how about just replacement rotors?
Old Nov 22, 2010 | 10:48 AM
PFC Brakes's Avatar
Yes I do have both
Old Nov 29, 2010 | 06:04 AM
PFC Brakes's Avatar
bump
Old Nov 30, 2010 | 06:40 AM
PFC Brakes's Avatar
bump
Old Dec 7, 2010 | 06:19 AM
PFC Brakes's Avatar
good morning
Old Dec 8, 2010 | 02:42 PM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
Hi, what you can offer for porsche 997 turbo?
Rgds, Karol
Old Dec 13, 2010 | 06:16 AM
PFC Brakes's Avatar
bump
Old Jan 3, 2011 | 06:31 AM
PFC Brakes's Avatar
bump
Old Jan 9, 2011 | 10:15 AM
spd dmn's Avatar
spd dmn is infamous around these parts
looking for replacement rotors for 997.1s
I do 3-4 track days a year
any recommendations please include price
