Agency power rear sway bar links for porsche 996 c2/c4
Old Aug 19, 2011 | 01:59 PM
JBFMCAR's Avatar
JBFMCAR is infamous around these partsJBFMCAR is infamous around these parts
Price: $85
Part fits: Porsche 911 996 Turbo, Porsche 911 996 Non-Turbo, Porsche Boxter/Cayman
Location (State): FL
AGENCY POWER REAR SWAY BAR LINKS
$85 + shipping
Had these on the car for a few thousand miles and then went a different roue with sway setup.
Product info:
Why sway bar links? The factory sway bar links utilize a simple design, ball joint and thin connecting rod. This style of links can be found on several makes and models of different vehicles. However, for the purist, the hardcore driver, and the weekend racer, these factory links are not enough. One of the first performance modifications you make in handling is the sway bars to assist with over and under steer. During aggressive driving scenarios, these factory links will flex and create a non rigid feeling. The Agency Power Rear Sway Bar Links for the Porsche 986 and 996 will change this immensely.
These rear end links are made of high grade 6061 CNC machined aluminum. The link maintains the same thickness throughout the length giving it a very strong structural integrity. The spherical bearings (monoballs) are used instead of urethane bushings for longevity as well as reduced noise. The bearings are sealed to prevent from wear and tear caused by dirt, water, mud, etc. Each bearing is held in place with a C clip to allow easy maintenance if desired. All hardware is stainless steel to prevent from rust and long term corrosion. The stainless metal collars are designed to give the link the correct alignment when attached to the shock body and sway bar. Each bolt uses an allen head for easy installation. Finally, the Agency Power Porsche Sway Bar Links are anodized in Royal Blue and engraved with the stylish AP logo. Not only standing out in your rear suspension setup, but offering you an edition that will truly enhance your handling performance.
Fits: Porsche Boxster 986 97-04 and Porsche 996 C2, C4 99-04 and 996 TT 01-05.
Old Oct 11, 2011 | 01:55 PM
JBFMCAR's Avatar
Price lowered
Old Oct 11, 2011 | 06:25 PM
JBFMCAR's Avatar
Sold
r_matt_6
Oct 8, 2015 06:07 PM
VGLNTE1
Aug 20, 2015 08:14 PM
TrackOne
Aug 20, 2015 12:56 PM
