911TT Engine Long Block Plus Part Out
Old Nov 24, 2011 | 01:11 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
Category: Accessories
Price: $1
Location (State): TX
These parts are off a wrecked low mile 2001 911TT 996 model. Although many parts will fit 997TT and GT3, GT2 996/997. Do your own homework on that for the most part please!!! I will do my best to help but don't want you using my brain....for free! If you are interested in an item pictured or not.... please PM me for any detailed pics. I will be updating with pictures as items are cleaned and photos taken. There are literally 100's of pieces not mentioned. Any item will be cleaned to the best of my ability before shipping.
If it's in, on, or part of the long block or a mentioned assembly and you don't see the item pictured here...please ask it may be obscured or behind another object. All internals, bolts, clips, clamps bolts, nuts, sensors, spacer, springs, clamps, clips, etc have or can be remoVed from the block and are for sale. Most of the big items i will allow an exchange (core charge) once a useable core is returned and we can discuss at sale if you are interested in that. Shipping cost are noted and apply to lower 48 states only. If shipping is not noted in price it will be calculated at sale. Sorry my lower case "V" doesn't work!!!
IMS SOLD
OIL PUMP SOLD
PISTONS SOLD
FLYWHEEL SOLD
FUEL RAILS/INJECTORS SOLD
OIL COOLER BRACKET 99610703373 SOLD
COOLANT PIECE 99610603973 SOLD
ALTERNATOR BRACKET 99631409104 SOLD
CRANKCASE SOLD
CRANKSHAFT & RODS SOLD
CONNECTING PIECES 99610644072 99610603973 SOLD
OIL FILTER BRACKET 99610703373
GT3 CRANK & ARROW RODS SOLD
CYLINDER HOUSING PAIR SOLD
TIMING CHAIN PASSENGER SIDE SOLD
1 CYLINDER HEAD SOLD
Oil Supply Return Line 99610701972 with 1 oil return pump 99610702172 and hardware. will do entire unit for $600 shipped or oil pump $300 shipped and return line $250 shipped.
Engine Oil Tank: the tank itself is damage but is not compromised $200 or BO shipped for anyone who breaks theirs changing their oil!! Most any sensor (oil leVel), nut, bolt, spacer, etc available too. also return line $225 shipped
ValVe Control: this entails intake/exhaust cams, IMS (if not sold), sprockets, driVe plate carriers,bearing pins, chain guide rails 99610503774 and 3874 $20 each shipped ,tensioner blades 99610516571 $15 each shipped, guide rail pieces $30 each shipped, and all associated hardware. IMS with chain wheel sprocket $350 shipped (SOLD). Cam lid 99610531574 $40 shipped
Camshaft Housing: Right housing $900 shipped, Right Vale coVer $600 shipped or $1500 shipped for the pair. also available are sensors, nuts, bolts, throttle actuators. Left side has been cold but cams and hardware available.
Cylinder Heads: Complete cylinder heads $1500 for the pair. includes Vales, springs, retainers, locks. hence the Complete head! shipping will be extra.
Top Side Oil Filter Bracket Heat Exchanger Assembly: can easily split these items up but $225 and $350 shipped. all connections, tubing, nuts, pipe, clamps, and bolts are available.
Timing Chain Adjuster and Housing: cases 99610514377 and 4477 are $250 each shipped or $475 shipped for the pair. Chain adjuster springs and assembly coVer $200 shipped
Belt Tensioner DriVe Belt Assembly: Part number 99611511270 other significant part numbers are for the rollers 99611501672, 99611501575, tensioner 99611522172. can be separated or complete for $800 shipped. connecting pieces $50 99610644072 $75 99610603973 shipped.
driVer side intercooler $50 shipped
oil filter bracket 99610703373 $225 shipped, with or without heat exchanger 99610702571 $275 and $325 respectively.
Throttle control element 99610530171 $75 shipped, and $100 shipped, $150 for both shipped.
Return oil pump 99610702172 $350 shipped, return line 99610702172 $250 shipped
Timing chain guide pieces 99610503774 and 99610503874 $30 each shipped.
Case through bolts 95910117301 and 96410117400 with washers $225 shipped for full set only.
Random brackets and other items PM for pricing.
AGAIN!!!! IF YOU DONT SEE IT, BUT NEED IT...... ASK!!!!!!
Old Nov 24, 2011 | 08:27 PM
pumptech's Avatar
more pics and thanks for the attaboy!! i know a lot of guys are not doing budget builds on these and the ones that need internals are upgrading to better rods at the minimum, but these parts are in good shape and could easily be shot peened for increased strength and durability.
i too was surprised to have no comments! at least its not the same old "USED TIRES FOR SALE" add. heads, cylinders, cams, and cam housings soon to come. and yes some of these items are on ebay as we speak and others are soon to follow.
By the way....THIS BLOCK IS A "0" for those of you that know what that means!!
Old Nov 27, 2011 | 02:40 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
props for taking a turbo engine apart!
I can't believe no comments...most people try to sell spare tires or an exhaust...this is cool!
I would list on ebay!
Old Nov 27, 2011 | 03:03 PM
pumptech's Avatar
I can say that haVing taken it apart it certainly was more fun than difficult, and while putting anything like this back together is always more difficult its certainly not rocket science. haVing built some engines in my past, i don't think things would be much more difficult than other engines. the problem is scarcity of information on tolerances, clearances, price and sourcing of parts, and other technicals. but if you had a year or 2 to take your time and source, read, and inform yourself it can certainly be done by most anyone who has built some engines in their past.
Old Nov 28, 2011 | 05:57 PM
x50plt's Avatar
x50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to behold
996 tt cases
I have a set of 996tt engine cases 2003 with 24,000 miles, with my engine build we went with a new gt3 block. If this helps anybody to complete the above package. asking $1200.00
Old Nov 28, 2011 | 07:07 PM
pumptech's Avatar
I'd do a package deal I suppose if anyone interested! I've got a GT3R crank and matching arrow rods that i plan on using but would let go for right price too.It would fit nicely into it. Bolt the heads on and you got a motor. Everything I own is for sale!! Il sell ya my dog!
Old Nov 29, 2011 | 09:09 PM
pumptech's Avatar
New head, crankcase pics and bump. No lifters available as i hope anyone would install new lifters . DriVer side cams, housing, and ValVe core available. Passenger side cams available with or without sprockets etc.
Old Nov 30, 2011 | 08:25 PM
Tim941NYC's Avatar
How much for the dog? lol. I also can not believe the lack of interest.
Old Nov 30, 2011 | 09:24 PM
pumptech's Avatar
i guess i couldn't sell the dog ....wifey would be pretty upset, and then would have to sell her too, but cheaper than the dog!!
getting to the end of the road with parts, just a few odds and ends left. should have it all up by the weekend to satisfy all the demand!! i'll have this stuff up for a while so it can be available for anyone. hopefully most will go a life time without needing new heads.
Added factory driVer side intercooler $50 shipped, oil filter bracket 99610703373 $225 shipped, with or without heat exchanger 99610702571 $275 and $325 respectively. Throttle control element 99610530171 $75 shipped, and $100 shipped, $150 for both shipped.
Old Dec 3, 2011 | 09:59 PM
pumptech's Avatar
This pretty well wraps it up for most part. Added factory fuel rails with injectors, return oil pump 99610702172 $375 shipped, return line 99610702172 $275 shipped, timing chain guide piece 99610503774 and 99610503874 $30 each shipped. Case through bolts 95910117301 and 96410117400 with washers $225 shipped for full set only. Random brackets PM for pricing.
If you see something you really like but price is not right, send me a PM and we can work something out, trades are just as welcome!!
Old Dec 6, 2011 | 07:50 PM
pumptech's Avatar
Bump....Rods only at this time as pistons have been sold
$500 for rods only.
Old Dec 24, 2011 | 12:50 PM
pumptech's Avatar
Holiday BUMP
Old Dec 27, 2011 | 08:32 PM
Tim941NYC's Avatar
Still have the pistons? Or are they sold?
Old Dec 27, 2011 | 09:16 PM
pumptech's Avatar
PMd....still have most
Items.
Old Jan 2, 2012 | 05:35 PM
pumptech's Avatar
Bump
