JRZ Suspensions Porsche-Lambo - PRS
Old Jan 11, 2012 | 10:36 AM
PRS's Avatar
PRS
PRS is infamous around these parts
Price: $5630
Private or Vendor Listing: Vendor Listing
Part fits: Porsche 911 997 Turbo, Porsche 911 997 Non-Turbo, Porsche 911 996 Turbo, Porsche 911 996 Non-Turbo, Ferrari, Lamborghini
Location (State): FL
Item Condition: Brand New
Performance Race Solutions is your place for JRZ suspensions and components. We offer complete service for this exemplary product. Their full line of products is available through us. We also offer Race-Spec alignments services and track prep.
JRZ designed the JRZ RS to give precise chassis control when driving on track and ultimate comfort for daily driving. Easy to install, the JRZ RS is available as a complete kit with mounting hardware and springs for all applications we support.
Following JRZ’s design philosophy, the JRZ RS has a large 22 mm diameter piston rod in strut applications and a 16 mm in aluminium damper applications. This means responsive chassis control at even the smallest suspension movements.
The large piston rod in combination with the high nitrogen gas pressure creates a lifting force giving great chassis control without using a high spring rate.
Our twin tube design uses a smaller diameter piston that gives a smooth feel during street driving. Working in conjunction with our blow off compression valving patterned from our racing dampers, the JRZ RS valving is the perfect marriage between daily driving and club racing.
To work with all ranges of spring and driver needs, the JRZ RS has an extra large adjustment range. With a few clicks you can turn your smooth street car into a crisp, rock solid track car in seconds.
Features
• 22mm piston rod
• Pre-set high gas pressure
• Piston developed for street and track
• Double adjustable
o 14 clicks compression
o 24 clicks rebound
• No canister • Large adjustment range
Pricing for the Lamborghini kit is as follows:
RS Pro damper system: $4085
Racing spring package: $840
Spring package for factory lift system: $630
This JRZ install on a Gallardo Superleggera done in house at Performance Race Solutions.
Pricing for Ferrari kits are similar to Lambo as both systems are eye-eye. The difference is that we only offer the racing spring package for the Ferrari. Some cars may want optional quick disconnect fittings on the lines for $720.
(407) 878-5870
sales@performancracesolutions.com
BenTT
Jul 22, 2021 02:38 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
Paseb
Sep 12, 2015 09:47 AM
