JL Audio HD900/5 Amplifier and JL Audio 10W6v2 Sub with Box
Old Dec 9, 2012 | 01:11 PM
Zubehor's Avatar
Zubehor is infamous around these parts
Category: Audio/Video/Electronics
Price: $0
Part fits: Porsche 911 997 Turbo, Porsche 911 997 Non-Turbo, Porsche 911 996 Turbo, Porsche 911 996 Non-Turbo, Porsche Cayenne, Porsche Boxter/Cayman, Porsche Panamera, Older Porsche, Ferrari, Lamborghini, Maserati, Aston Martin, Bentley, Nissan GTR, American vehicles, Other
Location (State): IL
JL Audio HD900/5 HD Series 900 Watts 5-Channel Class D Full System Car Amplifier
Less then 6 months old, and I will include the RCA cables, power/ground wiring everything you need to get it powered up and running. I also have the Amplifier Remote Level Control and Cable which is extra and was $40 but its included in the price. Asking $550 plus shipping.
http://www.jlaudio.com/hd-rlc-marine...essories-98118
5-channel amplifer
100 watts RMS x 4 at 4 ohms + 500 watts RMS x 1 (at 1.5-4 ohms)
75 watts RMS x 4 (at 1.5-3 ohms) + 500 watts RMS x 1 (at 1.5-4 ohms)
150 watts RMS x 2 bridged (at 3-6 ohms) + 500 watts RMS x 1 at (1.5-4 ohms)
variable high-pass filter on front and rear channels (50-500 Hz, 12 or 24dB/octave)
variable low-pass filter on subwoofer channel (50-500 Hz, 12 or 24dB/octave)
subsonic filter on sub channel (24 dB/oct at 30 Hz)
removable power and speaker plugs
optional wire remote for level control
Class D amplifier design
MOSFET power and output stages
differential-balanced inputs eliminate noise from your vehicle's electrical system
speaker- and preamp-level inputs (speaker-level input requires an otional adapter)
preamp outputs
4-gauge power and ground leads and a 60-amp fuse recommended - wiring and hardware not included with amplifier
no onboard fuses - when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended
10-3/4"W x 1-15/16"H x 8-5/16"D
JL Audio 10W6v2 10" 4 OHMs DVC Subwoofer in a sealed box enclosure. Also less then 6 months old. Asking $300 for the sub with the box plus shipping.
10" Dual 4 Ohms W6v2 Series Subwoofer
Power Handling: Peak 1200 watts / RMS 600 watts
Impedance: Dual 4 ohms
Polypropylene cone woofer
Radially Cross-Drilled Pole Piece
Massive Forced-Air-Cooled Aluminum Alloy Frame
Highly Linear, DMA-Optimized Motor System
Huge Diameter, Progressive Roll Spider
Co-Extruded Double Lead Wires
OverRoll Surround
W-Cone
Floating-Cone Attach Method
Plateau-Reinforced Spider Attachment
Ultra-Long Voice Coil
LuvPorsche
Dec 22, 2015 10:43 AM
iammulva
Sep 7, 2015 03:06 PM
WheelB
991 Turbo Vendor Classifieds
Sep 3, 2015 10:26 AM
