FS: 997.1 LED Taillights - Light Smoke - Flawless & no codes
Category: Lights
Price: $350
Location (State): SC
These are smoked the right way with an actual darker plastic used for the lens material itself, not spray painted with a black or grey paint and not by adhering tint to the normal color LED lenses. If you have a silver, black, or very dark grey 997 (Basalt, Atlas, etc) and want to get away from the red taillights that standout from your car, these would look awesome on your car. The LEDs are nice an bright - no issue with high visibility of the turn signals, brake lights, etc even through the lightly smoked lenses.
The Rear Fog light uses a normal Incandescent bulb, not an LED which I've included in the lights. Installation is really easy - the LED taillights connect with a single 6-pin plug right back to the OEM wiring harness plug - you don't have to connect each LED wire to the factory wiring harness. Resistors must be built into the wiring harness of the taillights as they do not throw any bulb-out warnings. Made by Spyder - 4 torx screws and 10 minutes and you'll have faster reacting, safer, cooler looking, LED taillights on your car.
PM or email me at petza914@gmail.com if interested and if you supply your e-mail address in the PM, I can send additional photos. Thanks.
Pete
Last edited by Petza914; Aug 6, 2013 at 03:36 PM. Reason: Posted in wrong category - moved to Lights
LED Taillights - Illuminated Photos
Mumureo, sure - here you go. Running Lights (when parking lights, headlights, or side marker when parked) and Brake lights share the same LEDs, applying the brake lights just increases the intensity substantially. Turn Signals are an Amber open triangle that surround the 3 White LED Reverse Light Triangle that's in the center. These are some of the only LED taillights that actually use LEDs for the Reverse lights, instead of an incandescent bulb.
Pete
Pete
oddjob142
Aug 19, 2015 12:27 PM
