Oem techquipment porsche crest center caps - black & silver
Old Aug 25, 2013 | 09:42 PM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
Category: Wheels & Tires
Price: $125
Location (State): SC
I have a set of 4 Used but in excellent condition Black & Silver Crest Porsche OEM Techquipment Wheel Center Caps. These were purchased directly from Porsche and come in the original box. I changed to RUF Center Caps on my R-Kompressor and don't foresee needing these again so I'm putting them up for sale. They are the slightly concave versions and fit virtually any Porsche or aftermarket wheel with the current 5mm x 130mm bolt pattern from the late '90s through 2012s. Caps have nothing to do with the bolt pattern, but I believe the centers of wheels prior to the 993 era may have had a different size center bore.
Price includes insured ground shipping within the CONUS. PM me or email to petza914@gmail.com
Thanks.
Pete
Name:	4 Fronts in Box.jpg
ID:	274601   Click image for larger version
Name:	4 Fronts.jpg
ID:	274602   Click image for larger version
Name:	4 Backs.jpg
Old Aug 27, 2013 | 09:06 PM
Petza914's Avatar
Dimension Info
Additinal Dimension Info on these center caps:
  • Total Outer Diameter - 76.62mm
  • Diameter of Inner clips @ bump that holds them into the wheel centers - 62mm
  • Diameter in Inner Clips at the recessed portion of the clip - 58.36mm
  • OEM Porsche Wheels they were installed on had a Center Bore ID of 62mm
  • Center Recess of wheel outside the center bore was 77mm
I had these installed on both an OEM Sport Design 19" Porsche wheel and on a Champion 19" RS171 wheel (which has kind of a unique tapered center bore) and it fit both sets perfectly.
Hope that helps.
Pete
Old Oct 3, 2013 | 07:59 AM
Petza914's Avatar
Bump
Old Oct 3, 2013 | 08:04 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
What color silver are these? I have the sport wheels that are GT Silver.
Old Oct 3, 2013 | 08:10 AM
Petza914's Avatar
These are the OEM silver. If you have Genuine Porsche wheels, they should match.
Old Oct 3, 2013 | 08:13 AM
Petza914's Avatar
My RUF R-Kompressor is GT Silver Metallic. Here's a picture of the crests on a set of Sport Design wheels on that car if that helps at all.
Name:	Sport Design on Silver 997.jpg
Old Oct 3, 2013 | 08:20 AM
Petza914's Avatar
...and here are a few where I had them installed on a set of Champion RS171 wheels on that same car.
ID:	286408   Click image for larger version
ID:	286409   Click image for larger version
Old Oct 3, 2013 | 08:26 AM
White Rock's Avatar
Do you know if all of the oem center caps are the same color, regarless of black and white crest or full color?
Old Oct 3, 2013 | 08:52 AM
White Rock's Avatar
Looks like my caps are actually GT Silver, therefore yours won't match.
Old Oct 3, 2013 | 09:53 AM
Petza914's Avatar
I don't know for certain, but would assume so unless wheels with matching center caps were special ordered. I've never seen a color code attached to a wheel center cap like you see with other painted trim pieces.
Old Oct 3, 2013 | 10:19 AM
White Rock's Avatar
Looks like the factory sport rims are the only rims with color matched center caps. Figures... (see link)
http://www.suncoastparts.com/product...97S_CenterCaps
Old Oct 11, 2013 | 08:53 PM
Petza914's Avatar
Bump
Old Oct 19, 2013 | 06:51 AM
Petza914's Avatar
Weekend bump
Old Nov 12, 2013 | 06:07 AM
Petza914's Avatar
Bump
Old Nov 25, 2013 | 08:55 AM
Petza914's Avatar
Still available.
