JRZ Porsche 997T RS-Pro Suspension Kit C4 05 - 11
Old Jan 7, 2014 | 07:45 AM
AMS's Avatar
AMS
AMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond repute
Price: $3799
Private or Vendor Listing: Vendor Listing
Location (State): IL
Item Condition: Brand New
JRZ Suspension Engineering offers the best high performance club sport damper available today. Combining the best aspects of our RS and 2-way racing damper, the RS Pro gives the owner ultimate suspension control while maintaining compliance for driving on public roads. A monotube double adjustable damper with adjustable gas pressure, the RS Pro offers an increased adjustment range allowing the user to tailor the car to themselves further. The RS Pro is available as a complete kit with springs and mounting hardware.
Features:
• 22mm rod strut, 16mm rod damper
• Mono tube
• Adjustable gas pressure
• piston sized for high performance
• street compliance valving
• precise canister
• large adjustment range
• Fixed hoses for easy mounting
• Steel piggyback
Taking club sport performance to the next level, the RS Pro has a remote canister with a progressive blow off system. Progressive blow off allows for a stiff compression valving while maintaining smooth response. The result is a damper that provides ultra solid platform with smooth bump compliance. The JRZ standard large 22mm piston rod works in concert to maximize blow off valve response to great chassis control without using a high spring rate in strut applications. In damper applications the piston rod diameter is 16mm to achieve a balance between ride and control. JRZ RS Pros are shipped with fixed hoses to make mounting easy and straightforward. A fixed hose also helps control the movement of the hose in the wheel well making it less likely that the hose will rub moving parts. JRZ RS Pro damper kits are available in piggyback configurations. The canister can be fixed to the damper for ease of installation. The monotube design makes use of our unique RS Pro piston. By moving more fluid than our standard club sport damper, the RS Pro achieves a higher level of chassis control. To customize track to track setups and tailor the chassis to the JRZ RS Pro has an extra large adjustment range. Each adjustment is designed to be an even step giving you predictability when making changes. JRZ club sport dampers are designed to give the chassis tuner ultimate control.
Benefits:
• Better chassis control for higher rate springs / power / aero
• Street ride, racing performance
• Easy to change configurations
The design of the RS Pro takes you to the next level. Stiffer cars with higher levels of power demand the control JRZ can supplies. With the control of gas pressure charge as well and compression and rebound adjustments, the RS Pro will get the most out of your high performance car. The JRZ RS Pro is shipped as a bolt on kit with installation instructions and always comes with our world renowned personal service JRZ.
Recommended applications:
• Highly modified Street/DE
• Experienced Club Racing
JRZ recommends the RS Pro for premium high performance street drivers, experienced club racers and entry level professional racers.
Please Note:
This JRZ Suspension for 997T is NEW , but has just a few minor cosmetic scratches and scuffs from being handled out of the packaging.
Regards
Larry
ID:	318022   Click image for larger version
ID:	318023   Click image for larger version
COBB Tuning
Jan 1, 2025 09:02 AM
joseph_number1
Jul 19, 2018 05:45 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
TrackOne
Aug 20, 2015 12:56 PM
