FS: EvoMS 65mm "775 kit" VTG's with EvoMS Diverter Valves
Roughly 7.5k on this setup, no cores required at $3500
I made 719awhp and 696tq with these with about 30hp/tq left to go before they're out of breath. Direct bolt on vs stock setup. Asking $3500 + shipping for these. Pictured here in the back https://www.6speedonline.com/forums/...p;d=1394754296 |
your worse than randy!!! :)
Whats in it? What are the supporting mods needed to hit that?
What's in what? I have the full evo 775 kit on my car, I'm parting with the turbos and forged valves.
Originally Posted by dhahlen
(Post 4103304)
THE EVO775 kits have 65mm.
Ahhh! Thank you. Yes, 65mm. Tial builds the setup for Evo.
bump!
Alpha time... time to go!
What were your supporting mods and type of fuel to hit 719AWHP?
That sounded like a killer street set up man!! If I am not mistaken, did you bend your rods with this set up? That alot of low end hitting torque with those VTG's...again must of been a killer streetable machine!! The key would be to bring and limit the tq gradually in the tune.
(Post 4103139)
Hi Bobby,
I did a whole write-up on the kit here: https://www.6speedonline.com/forums/...ls-inside.html Note this article was done when I was running 100 octane with 200 cel cats. I switch to E85 and went catless and picked up a little more power. No bent rods, car is still running great! They do a decent job, but certain alpha setups can get a lot more low end power. I get boost around 3200rpm and they hit hard at 4000rpm. Supporting Mods: EVOMS 775 Kit which includes: -EvoMS Billet Upgrade 65mm VTG Turbos -EvoMS Clubsport Intercoolers -EvoMS Turbo manifolds -EvoMS Turbo inlets -EvoMS Boost Hoses -EvoMS Upgraded BPV -EvoMS Stage 3 Clutch -EvoMS 82mm Intake Plenum (IPD) -EvoMS 80mm Throttle Body (GT3) -EvoMS Upgraded Coil Packs -Upgraded Spark Plugs for EvoMS 775 Kit -BBi Barcode Exhaust w/Cat Delete -EvoMS Leakproof Kit for Throttle Body/Intake -COBB 1000cc Injectors -Cobb Access Port with 91 pump, 100, and e85 tunes (personally tuned by Cobb!) |
Great seller and price. GLWS Darren.
The 719awhp was done on what type of dyno? Dynojet, dyno dynamics, mustang?
-Jose |
Mustang
Sold!!
| All times are GMT -6. The time now is 06:01 PM. |
