WTB - 997.2 PSE mufflers
Old Feb 21, 2015 | 07:35 PM
Mark Harris's Avatar
Mark Harris is infamous around these parts
Category: Accessories
Price: $1
Location (State): KS
Looking for a used set of 997.2 PSE cans.
Old Feb 26, 2015 | 08:55 AM
StormRune's Avatar
StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !
Here's a bump and a comment. Be sure to try to get the tips at the same time. Getting them separately can be expensive... unless you've been lucky enough to get some already. The non-PSE tips are not compatible.
If you go forward with this and decide you'd like to add a switch for them, I can provide pointers. I assembled the factory switching parts and vacuum lines and installed them to spec, but rather than doing the computer-driven hookup, I used a hardwired switch to turn them on/off at will without interference from the computer. I also saved money not buying the OEM switch and harness that way. I can also send you the factory doc describing the installation of the vacuum lines.
If you don't have a center bypass, you will be fine with it on all of the time (its default position with no vacuum hookup). If you have a center bypass, you may or may not want the switch. There were times in my quiet neighborhood where I wanted the car to be more subdued.
joeyharp
Aug 29, 2016 09:41 PM
Fieldsport
Dec 2, 2015 06:31 PM
mxracer
Sep 17, 2015 05:30 AM
MNemeth
Sep 9, 2015 11:30 AM
shiftmechanism
Sep 4, 2015 04:14 PM
