996 turbo cam timing tool wanted
Category: Accessories
Price: $500
Part fits: Porsche 911 997 Turbo, Porsche 911 996 Turbo
Location (State): WI
You can get a Stomski dial indicator type for 800 and just use a 360 degree wheel on the crank pulley. It is best to find a shop that has them and just pay them to do it. It is a quick job.
still need the cam locking tools for the nuts on the front of the cams. 2 different size tools
the intake cam gets a set ft/lb plus 170* and the exhaust cam gets a set ft/lb and 90*. the tools are needed to hold the cam in place and not move while another person cranks the snot out of the bolt.the intake cam has to be held at the outmost counterclockwise position when torquing the bolt. this is why the tools have **** on the end to lock into the cams themselves.
he has made the locking tools but uses baum cam plates
these tools have 2 different size diameters for intake and exhaust http://www.baumtools.com/shop/01engi...l#.WOt7lFKZNE4
http://www.baumtools.com/shop/01engi...l#.WOt6X1KZNE4
http://www.baumtools.com/shop/01engi...l#.WOt69VKZNE4
http://www.baumtools.com/shop/01engi...l#.WOt7U1KZNE4
that only works if the notch is in the correct position. if you allow the cam to move especially the intake cam you change the vario cam timing. having had to do this 3 times to get the timing right its not an easy task to backyard it. better to have the proper tools from the start
