Turbo Kraft Front & Rear Monoball Camber Plates
Old Jul 7, 2017 | 05:53 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Category: Accessories
Price: $450
Part fits: Porsche 911 997 Turbo, Porsche 911 996 Turbo
Location (State): CA
Turbo Kraft Front Monoball Camber Plate Set AWD ONLY MSRP $500 SOLD
Turbo Kraft Rear Monoball Camber Plate Set 2WD & AWD MSRP $420 SOLD
Front Monoball Camber Plate Set : 4WD (WIDEBODY)
A performance upper strut mount set replacing the original elastic, damper to chassis mounts. Built in position offset allows for an expanded range of camber adjustment progressively based on vehicle ride height. Typically, 1 to 1.5 degrees of additional negative camber adjustment can be achieved. CNC machined billet aluminum alloy, hard anodized. Includes high quality, Teflon lined self-lubricating spherical bearings and zinc plated hardware. Strut shaft hardware kit included for M14 x 1.5 thread type.
REAR Monoball Shock Mount Set : Upper
Replaces the original rear elastic, noise insulating mounts. Featuring a wide angularity solid type monoball connection directing more compression and rebound forces to the dampers. Of motorsport quality. CNC machined billet aluminum; zinc plated steel hardware, self lubricating bearings. Application intended for threaded body dampers. Shock hardware kit included for M12 x 1.0 thread type.
Old Jul 7, 2017 | 07:40 PM
VID997's Avatar
!!! SOLD !!!
Old Jul 8, 2017 | 03:56 PM
VID997's Avatar
FRONT AWD ONLY CAMBER PLATES ARE STILL AVAILABLE!
They are pictured above on the left and have an "R" & "L" stamped into them.
Old Aug 28, 2017 | 03:40 PM
VID997's Avatar
!!! SOLD !!! Front Camber Plates
