VelocityAP Aston Martin V8 Vantage Lowering Springs
Category: Accessories
Price: $600
Part fits: Aston Martin
Location (State): NC
Item Condition: Brand New
I decided to move to a new project before installing. These go for almost $800 after shipping and taxes.
My loss is your gain.
http://www.velocityap.com/Aston-Martin-V8-Vantage-Sport-Lowering-Springs-p/vel-amv8springs.htm
Set of 4 VelocityAP lowering springs for Aston Martin V8 Vantage Coupe & Convertible, to reduce the ride height on your car by 7/8", or 22mm.
VelocityAP springs use exclusively high quality, high stress X5K Spring Steel. Although considerably more expensive than regular steel, this new generation steel allows us to further improve upon the original Jaguar F-Type spring design by reducing the amount of steel required in a spring. VelocityAP springs are therefore substantially lighter (by approximately 30%) and reduce the solid height therefore increasing travel. X5K Spring Steel is used in almost all top levels of Motorsport, giving a hugely successful endorsement of its characteristics & proven durability.
In addition to the superior materials, these springs also feature a unique manufacturing process that sets them aside from most OEM & Aftermarket applications - a Tapered Wire Progressive Rate design. The Ultimate in Design. The principle is simple: By using a tapered rather than constant diameter spring wire, our springs achieve a truly progressive spring rate over the length of their compression & travel. The spring rate increases when you need it (cornering) and decreases when you don't - yielding a smooth and supple ride over bumpy surfaces. The best of both worlds!
By using this unique manufacturing method, we can achieve a substantial increase in spring rate with huge handling benefits with no loss of ride comfort. As the spring de-rates, the shock absorber no longer struggles for rebound control and gives improved vehicle stability.
Benefits:
Reduced Weight
Improved Ride Quality
Improved Handling
Better Visual Appearance
Improved Shock Absorber Function
FITS ALL V8 VANTAGE MODELS, COUPE AND CONVERTIBLE EXCEPT
Benefits:
Reduced Weight
Improved Handling
