FVD "Brombacher" Exhaust 997 GT3/RS (Sound Version)
Old Jul 27, 2017 | 05:17 PM
dkirvida's Avatar
dkirvida is infamous around these parts
For sale is a used FVD "Brombacher" Exhaust system for the 997 GT3/RS. Original MSRP of $6,367.00. Recently off a 997.1 GT3; this system shows a manufacture date of 2012 and has less than 4,000 miles on it.
$3500 OBO
https://www.fvd.net/us-en/BES9971526...r-exit-ti.html
Specs:
- + 25 crank hp & + 25 crank torque
- 200 Cell high flow, tri metal german HJS sport catalysts
- 2 3/4" tubing (70 mm) straight through design for max. power
- Equal length header set up for maximum torque gain
- Weighs 71 lbs. (32,2 Kg),
- 15.5 lb (7 Kg) weight savings over stock
- T 316 stainless steel for improved durability over T 304
- Includes all necessary clamps and mounting brackets
- 2 x 3.5"(90mm) round center exit tips
- Made in Germany
- Intoxicating growl at idle, partial throttle and wide open throttle
- No DME programming necessary
FVD is proud to introduce our newest line of Brombacher exhaust systems. Brombacher exhausts are engineered for the discerning Porsche® owner and offer unmatched performance, unparalleled quality, and incredible value. All of our exhausts are manufactured in Germany and are tested comprehensively for flow rate and characteristics, thermal stress, resistance to cracking, and longevity. To further ensure quality, all of our exhaust systems meet the standards of the German independent testing agency TÜV; whose quality standards are among some of the strictest in the world.
The Brombacher 997GT3 Exhaust system give the GT3 an intoxicating growl across the rev range and eliminates unwanted frequencies and ensures no resonance or drone in the cabin.. The end result is a strong, linear, firing-order dominated flat-6 Porsche® sound. In addition, Brombacher exhausts systems are available for ultimate performance full titanium. Each of our exhaust have been extensively tested on both a chassis and engine dyno as well as logged thousands of miles on both the street and at the track. All this research, development and testing ensures maximum horsepower gains throughout a broad power band; all while maintaining reasonable sound levels for the street and provide a distinct, sporty exhaust note that is purely Porsche®.
Installation made easy! Replace worn hardware and gaskets with one of our prepackaged installation kits.
Use part #: FVD MK9 972 02
Like all European Vehicles, FVD parts are TÜV approved. What is TÜV approval you ask? Basically, German-registered road vehicles may not be operated on public roads without a certificate from the TÜV. Also, all modifications must be approved, from installing tires of a different size to materials used in nuts and bolts. TÜV's safety guidelines are among the strictest in the world, and getting a road permit for thoroughly customized vehicles borders on the impossible.
We strongly suggest replacing worn gaskets and hardware with our pre-packaged installation kits.
FVD's parts passed these criteria in order to obtain the TÜV stamp of approval:
