FVD 66mm VTG turbos
Old Nov 6, 2017 | 09:48 AM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
FVD 66mm VTG turbos
Category: Engine - Power Adders
Price: $2800
Location (State): FL
FVD 66mm VTG turbos
FVD Brombacher 997.1 TT “700 Series” Upgraded Turbos
Facts:
- CNC re-profiled compressor housing and backing plate
- New, lightened and larger compressor wheel (12 blades)
- Reworked turbine wheel, lightened and optimized for higher flow and reduced backpressure.
- All new bearings.
- All new piston rings and seals.
- All parts cleaned, inspected and measured to motorsport specifications.
- All parts are balanced (static & dynamic) up to 120.000 rpm with balancing protocol.
- 47.55 mm inducer
- 66 mm exducer
- Flow rate = 37 lbs. / minute or 280g/s
- Remanufactured by Borg Warner certified technicians
- Shaft tolerances are strictly maintained to ensure durability
- Free software update for those already running FVD Software
We start by re-profiling the OEM VTG turbocharger compressor housing and modifying the compressor backing plate. This is done to replace the factory compressor wheel with a larger 12 blade, modified compressor wheel. The larger wheel is also lightened allows the turbo to flow a larger volume of air (more power), and aids in quicker spool up.
In addition we increased the size of the inducer and exducer to compensate for the higher volume of air traveling through the compressor. We increase the exducer on the turbine side to 66mm (OEM is 60 mm) and the inducer to 47.55 (46.9 mm). These larger sizes were achieved with larger factory housings, which allow our turbos to be cost competitive and are done on an exchange basis.
Borg Warner certified technicians remanufacture our turbos. This ensures reliability, superior performance and cost effectiveness. They ensure that each individual part is within the specified Borg Warner tolerance.
Combined with our proprietary software, exhaust, BMC drop in filter, and other engine components you can achieve 750+ crank hp
Old Nov 6, 2017 | 09:53 AM
turboslut's Avatar
Pics added.
ID:	515596   Click image for larger version
ID:	515597   Click image for larger version
Old Nov 6, 2017 | 11:28 AM
nzskater's Avatar
nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !
Did you end up installing these? Do you know how many miles are on them?
Old Nov 6, 2017 | 11:30 AM
turboslut's Avatar
bought them off of a forum member with 5800 miles on clock. I saw/felt them run on his vehicle and then personally saw him take them off the car. Since that date...they have been in my closet in a box.
Old Nov 9, 2017 | 06:16 AM
turboslut's Avatar
Sold to:
Daniel Seemann
And
Eduardo Flores Sanchez (member: rok_16)
