Aston Martin H&R Spacers (23mm)
Old May 9, 2020 | 08:14 AM
TiAg's Avatar
TiAg is infamous around these parts
Category: Wheels & Tires
Price: $170
Part fits: Aston Martin
Location (State): FL
Item Condition: Brand New
H&R 23 mm spacers for Aston Martins.
Price: $170 shipped. (these are about $270 plus shipping brand new)
Part Number: 4665681
Fitment: Will fit most Aston Martins - check out
trakplus.com , click on "Find Application" and enter part number above to check fitment
Whats included: two spacers (one pair) + 10 bolts to mount the spacers to the hub. (you use your stock bolts to mount the wheel to the spacer). *** Puppy not included ***
Condition: basically brand new - one spacer was test fitted and immediately removed ​​​​​. The only reason I couldn't use these is because the cavity on my stock 2011 Vantage S wheels was not wide/deep enough for the stock studs. From what I understand, it should fit stock sport wheels without having to grind the studs but buyer is responsible for checking fitment prior to purchase. 23 mm is the perfect size for the rears.
Old May 9, 2020 | 03:15 PM
johnsons's Avatar
johnsons is infamous around these parts
If possible do you have a picture of your wheels? I am looking to get spacers and want to see if we have the same wheels to see if I will have that same issue.
thanks!
Old May 9, 2020 | 03:42 PM
TiAg's Avatar
thanks!
See attached image. They won't fit on these wheels without some modification to the cavity or studs. From my research on the various forums, i think it would work on the regular sport wheel without modification. Also think it would work on DB9s and DBSs.
Old May 9, 2020 | 03:46 PM
johnsons's Avatar
Thanks for the response and picture. We do have the same wheels. I’m trying to figured I out if I am willing to grind/cut the bolts or just aftermarket wheels. Thanks!
Old May 9, 2020 | 03:49 PM
TiAg's Avatar
Bummer. The 11mm ones that H&R makes do not require any modifications. That's what I have up front. I just ordered a 2nd pair of 11mm's for the rear. I believe that's the only option if you want to avoid modification to the wheel/stud.
Old May 9, 2020 | 03:51 PM
johnsons's Avatar
Thanks for the advice! I appreciate it. If I decide it is worth it I will let you know.
Old May 18, 2020 | 08:13 AM
TiAg's Avatar
Bump. Willing to accept reasonable offers.
Old Jun 1, 2020 | 10:49 AM
TiAg's Avatar
Bump
Old Jun 12, 2020 | 11:30 AM
TiAg's Avatar
Sold
JanVH2
Jul 19, 2018 03:08 PM
sanengo
Sep 18, 2017 04:56 PM
TiAg
14
Oct 15, 2015 11:45 AM
