Hello I have a set of kw clubsports for the 997 2wd that I removed from my car before selling. Never drove the car and coilovers have less than 800 miles. Comes with top mounts and 2way adjustable. Cost me a little over 5k. Asking 3900 obo.
mytee10@yahoo.com
Thanks, really solid set up. 2 way rebound/bump adjustable with attached reservoirs so makes for a clean install without messing with canister mounting.
KW part number 35271815
Im not too familiar with the 997 awd chasis but if anything like the 996 2wd to 4wd, the rears should be direct swap for awd. Fronts will most likely need top mounts and if similar the 996 2wd to 4wd will need a sleeve to go over the lower shock body to fit the awd carrier, you can get these from jrz/moton/mcs/kw, inexpensive part if needed.
