FS: BF Goodrich G-Force R1 rear tires (285/18
Old Aug 31, 2007 | 11:03 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Used for approx 200 miles (no road track miles, just a few 1/4 mile runs and street use to get to the track - like new, nothing wrong - going to try drag radials instead). Paid $670 for the set - will sell for $500 delivered in cont. USA. These are R compound road race tires in like new condition...
Size: 285/30ZR18 Wt. 24 Lbs. each - outside diameter: 25" (will work with Michelin Pilot Sport fronts and AWD without issue)
From the BFG web site:
The g-Force R1 radial is BFGoodrich's Track & Competition DOT racing tire developed for prepared vehicles looking for race- and time attack-winning performance, as well as track-day drivers seeking predictable grip that is comfortable to drive at the limit. The g-Force R1 radial is designed to offer best in class dry grip, cornering power, steering response and turn-in precision to inspire driver confidence for the quickest times lap after lap.
The g-Force R1 uses a competition tread compound molded into a symmetric, non-directional, semi-slick tread design with just 4/32" of beginning tread depth eliminating the need for shaving. Rubber bridges are molded repeatedly across the two DOT-required circumferential grooves to promote even wear and further the tire's slick-like performance. While the tires require minimal scuffing, heat cycling is recommended to further enhance consistency and wear. The tread compound warms up quickly and operates over a wide temperature range to provide predictable grip that is forgiving and easy to drive at the limit. The symmetric, semi-slick tread design allows the g-Force R1 to rotate in different directions and be used at different vehicle wheel positions to maximize treadlife. The tire's internal structure includes twin steel belts reinforced by a spirally wrapped polyamide cord on top of a two-ply nylon cord carcass.
Old Sep 5, 2007 | 09:46 PM
John D's Avatar
I would like to move these...price reduced to $425 delivered...
Old Sep 18, 2007 | 09:21 PM
John D's Avatar
$395.00 or best offer...delivered. Surely someone can use these at 1/2 price. They are brand new!
oufan2929
Nov 8, 2015 08:26 PM
L.A.P.
Oct 19, 2015 10:01 PM
Nikg
Sep 21, 2015 10:32 PM
L.A.P.
Aug 23, 2015 11:48 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
