check oil level
Old May 25, 2012 | 01:05 AM
ccwboy's Avatar
ccwboy is infamous around these parts
check oil level
the warning light check oil level is on.check the dip sick and fill 1L.the warning still on.and fill 2Liter now.light still on..but the dip stick on Max level.don't want to damage the engine.but i should fill again or let the warning light on??
read the manuel said::so i should keep fill more to try??
(((not necessary to top-up oil, unless the warning message check oil level and the relevant warning symbol...))
Old May 25, 2012 | 05:55 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
If you added oil and dipstick says full, my gues is you are ok BUT i'll call the service center as:
engine (minus) - oil = very bad
engine (plus) + too much oil = bad
If you know someone with a ODB reader or the VAG-COM system (local VW dealership) they can have a better look at the error code.
Old May 26, 2012 | 02:34 AM
ccwboy's Avatar
yes dipstick says full.i think the sensor error or something.gonna go to service as well.
Old May 26, 2012 | 03:53 PM
That seems to make sense.
Old Jun 6, 2015 | 02:36 PM
flittlejr's Avatar
flittlejr is infamous around these parts
I don't trust lies so today I was going to check oil level manually. Pulled dipstick but all it has is yellow dot on end. There was nothing on it. Is the full when touches yellow dot? Service done 5K ago.
Jul 29, 2019 11:13 AM
tkebp1275
Aug 31, 2015 06:35 PM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
