Solenoid clicking sound near starter battery
I Installed a small amp and sub and have been noticing a loud click from my starter battery after the Install, I pulled a ground off the negative of the starter battery, you think this is the reason?
It clicks when I start the car and maybe 20 seconds after I turn the car off
Everything else seems to be normal
Am sure you don't mean eliminated/removed a ground wire from the starter battery when you say 'pulled'.
So you must mean you are using the ground of the starter battery so i'd just move both the + and - to the other battery and see what happens. Remember to have a proper fuse on the + side around SIX INCHES OF ACTUAL CABLE LENGTH away from the + of the battery for safety sake.
Ya I just jumped off the ground
The positives off the acc batt on the driver side it's fused
I'm going to get a new ground cable and run it off the driver side batt
And see if that fixes it
Ferrari
Aug 24, 2015 04:35 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
