Power steering issue?
Old Aug 6, 2013 | 03:29 PM
ek1's Avatar
ek1
ek1 has a spectacular aura aboutek1 has a spectacular aura aboutek1 has a spectacular aura about
I have a weird issue. Power steering does not work until the engine RPM is at about 1000. Anything below that makes the steering wheel progressively hard to turn as RPM gets lower. At idle (around 500 RPM) the steering wheel cannot be turned at all. All of this happens while the car is stationary (obviously it's easy to turn the wheel once the car is moving).
Is my power steering pump dying/dead or is power steering fluid level too low? I looked inside the reservoir and it's about 50% full. I also don't have any lights or error messages on the display.
Old Aug 7, 2013 | 01:22 PM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
Put some fluid in and see what happens.?? 50% sounds like half empty.
Old Aug 7, 2013 | 09:05 PM
ek1's Avatar
ek1
Unless someone knows the exact level the fluid should be at, I am not going to experiment with it. There are no markings on the reservoir itself and the manual contains zero info about it. The dealership is picking up the car on Monday....let them deal with it.
Old Aug 8, 2013 | 06:52 AM
That's what I'd do.
Old Aug 15, 2013 | 06:57 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
So.......
Any news on this issue ??
Old Aug 15, 2013 | 03:48 PM
ek1's Avatar
ek1
Originally Posted by Sunnyside
So.......
There is something wrong with the pump (one of the seals is bad or something). They are replacing it and replacement has to be shipped from the UK (weird, I guess they do not fail that often).
Old Aug 15, 2013 | 03:54 PM
OK , that's weird. If you get any more info on the failure once its been fixed please let us know
Old Sep 21, 2013 | 06:43 PM
ek1's Avatar
ek1
Here is exactly what the dealership service department wrote:
CLIENT STATES STEERING FEELS HEAVY AND POWER STEERING SYSTEM IS MAKING NOISE . INSPECT AND REPORT
PUMP LEAKING
48999999 1.0 CHECK FOER LEAKS AND CLEAN UP AREA
48999914 2.4
01210000 .5
4899 I 0050
I CHECKED THE POWER STEERING SYSTEM FOR LEAKS I FOUND THE
POWER STEERING PUMP LEAKING MINERAL OIL BY ITS FRONT SEAL CC
I REPLACED THE POWER STEERING PUMP ,I BLED THE POWER STEE
RING SYSTEM AND ROADTEST THE CAR .. THE POWER STEERING SYSTEM
IS NO LEAKING AND IT IS NOT MAKING NOISE.
Michael_s
Sep 11, 2015 08:03 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
Zero911
Aug 24, 2015 06:51 PM
JMon
Aug 21, 2015 08:20 AM
