Battery Low and Running Gear Fault - Related?
Old Sep 10, 2013 | 10:10 AM
ccwboy's Avatar
ccwboy is infamous around these parts
i just change the new battery.my new life is back on
Old May 23, 2015 | 09:53 AM
tmacapollo's Avatar
tmacapollo is infamous around these parts
I have a similar problem Cliff but the car would not start... so I replaced the right (smaller Battery)and it cranks up great...Still getting the "Low Battery" and Suspension Fault ... I connected the Bentley maintainer to the left battery and let it run for 36 hours. Can you explain your post about "Its the main battery if you put the key in turn to the left for 4 seconds then turn to the right and start it".
Is the "main" the left battery? If I replace that will the systems/ECU and radio have to be "re-booted" by Bentley's restart procedure? Will I need to reprogram key and put in Radio code???
Old May 23, 2015 | 09:59 AM
cdavis43's Avatar
cdavis43 is infamous around these parts
Just replace nothing to reset. That's was my situation.
Cliff
Old May 23, 2015 | 11:34 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
You will have to reset the windows. Easy though and possibly the seat memories.
Not sure if the gearbox will have to re-learn, maybe, but I'm sure someone on here will know.
COBB Tuning
Jan 1, 2025 09:02 AM
gulf gt
Aug 27, 2015 10:27 AM
'02996ttx50
Aug 26, 2015 05:56 AM
DSCOFF
Aug 23, 2015 01:22 PM
