VagCom Help
Old Sep 23, 2013 | 03:34 PM
White991TT's Avatar
White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !
VagCom Help
Need your help... working on clearing codes and keep getting the following:
Anyone know how to proceed with adaptation? TIA
Address 26: Auto Roof Labels: None
Part No: 3W7 959 255
1 Fault Found:
02024 - Perform Adaptation
005 - No or Incorrect Basic Setting / Adaptation
Old Sep 24, 2013 | 12:47 AM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
the roof needs to be set,should be a option for setting roof .you may have an issue with the switch on the side of roof,i believe its on the left hand side of the bow hinge,may have fallen out of its retainer. to do it manually operate the roof in its full cycle which would include window drop and window raise,then recheck for faults.
Old Sep 24, 2013 | 12:56 AM
White991TT's Avatar
Thx B Tech! Will check for the switch at the bow as youve mentioned. Also any info on setting the roof via vag com? Lists a number of code settings within conv module.
Old Sep 24, 2013 | 01:26 AM
it should tell you to sweep the roof as you go through the settings,i am out of town at moment but when i get back i will check with mine.
Old Sep 25, 2013 | 01:49 AM
White991TT's Avatar
Thx B Tech! Switch appears to be positioned correctly. Tried conv adaptation and channels 1,2 and 3 were without error. Channels 4 and up show an error in the adaptation module. Not really clear how to manually perform adaptation? Top works fine without issue would simply like to perform adaptation to clear this hidden code.
[IMG]
[/IMG]
Old Sep 25, 2013 | 02:02 AM
sorry didn't explain switch location very well ,in your first picture can you check the switch that is attached to the leg in bottom left of your first picture,it should have tape round it to hold in position.
Old Sep 25, 2013 | 05:58 PM
White991TT's Avatar
Not to worry, You were right! Appears the sensor became dislodged and somehow became tangled within the top arm mechanism?? I will work to untangle it and try and reassemble. Looks like a clip is also damaged. Attached a few pics for reference.
[IMG][/URL]
[/IMG]
jc_333
Bentley
Mar 25, 2023 05:06 PM
MikeH
Bentley
40
Apr 25, 2017 11:54 AM
gsav69
Lamborghini
Aug 20, 2013 06:42 PM
MikeL
Cayenne 958
Jun 4, 2013 10:01 PM
jc_333
Bentley
Jul 13, 2012 09:55 AM
