Removing Gear Knob (I know.. many topics already)
Removing Gear **** (I know.. many topics already)
Hi ,
What is the best tool to wedge between the gear **** and the shrud? Many topics mention plastic card. Does credit card work? If not, what is the best common household tool I could use?
I tried to use a screwdriver but was afraid to nick the surface.
can you get some scotch tape and wrap it round a knife ,if not anything plastic with a bit of substance to it,credit card is not strong enough. if you have strong fingers and clean surface i have done it by that way,grip the collar and push down,it is only a plsatic collar holds it. make sure gear shift is is neutral and moves across to the left.
I used a credit card to wedge in at the rear side of the **** since it has the largest gap. I slowly wiggle the card card, starting from the rear and slowly work around the ****.
Now, I need to figure out how to put it back.
smartbot
Jul 18, 2016 01:15 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
