Removing gear knob?
Old Jan 2, 2014 | 04:18 PM
gurdas's Avatar
gurdas is infamous around these parts
Removing gear ****?
I've got a brand spanking new Mulliner gear **** waiting to be fitted, anyone removed and fitted one before? Is it easy and do I need any tools?
Thanks,
G
Old Jan 2, 2014 | 06:42 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
Hi Gurdas,
I've installed mine few months ago. There are several threads before about this topic. BentleyTech posted a diagram which is very helpful. You can do a search.
I used an old credit card to wedge between the gear ****. Find the place that has the largest gap and wedge your card it. Slowly wiggle your card across the entire **** to increase the gap. Eventually, you will be able to pop off the old ****.
You need to be patience and do it slowly. Don't use any metal instrument because it will nick you gear shifter.
Old Jan 2, 2014 | 10:06 PM
gurdas's Avatar
Thanks for this! Will attempt it in the morning.
Old Jan 3, 2014 | 04:19 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
move the shifter to neutral and move across to manual mode ,then use a plastic tool to push down on lower collar,once collar is moved down pull up on ****.
Old Jan 4, 2014 | 02:22 AM
gurdas's Avatar
Thanks for the help, finally fitted, the sleeve was pretty easy to move down by hand, bit tricky to pull it back up though once the new **** was fitted but managed to do it eventually with a bit of jiggling around.
smartbot
Jul 18, 2016 01:15 AM
davetherave
Bentley
Sep 16, 2015 06:30 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
GSP
Sep 9, 2015 05:31 AM
AM v12v
Sep 4, 2015 02:52 AM
