Bentley 07 Coupe Tire pressure RESET
Old Oct 5, 2014 | 04:03 PM
rdsrllc's Avatar
rdsrllc is infamous around these parts
Hi, I got a Bentley 07 Coupe and need to RESET my tire pressure. how can I do that? light came on, put air on tires and it doesn't go away.
Old Oct 6, 2014 | 03:18 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
The owner's manual explains the process. If you don't have the manual, PM me and I'll provide the info.
Old Oct 8, 2014 | 12:51 PM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
I did it once after reading the manuel. i could not recall the procedure but if i did it, it can't be all that bad.
Old Oct 8, 2014 | 01:41 PM
Bentley Tech NC's Avatar
Bentley Tech NC has a spectacular aura aboutBentley Tech NC has a spectacular aura aboutBentley Tech NC has a spectacular aura about
Its simple. start the car ,hit the Vehicle button, then press button that says (new spec pressures) Drive car and wait for hour glass to disappear , you should be able to see tire pressures on the infotainment. If not you might have a fault in the system
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
