Special proceedure for changing brake fluid?
Old Aug 10, 2016 | 06:28 AM
MrVette's Avatar
MrVette is infamous around these parts
My brake fluid is discolored. That typically indicates it has some moisture in it. So I want to do a fluid flush.
In some cars you need to shut down the ABS with a scanner before changing the fluid. Is there any such special procedure for a 2008 GT Speed?
I have the shop manual CDs on order but would like to get on finishing up my 8 year service.
Old Aug 10, 2016 | 08:06 PM
Swflbt23's Avatar
Swflbt23 has a spectacular aura aboutSwflbt23 has a spectacular aura aboutSwflbt23 has a spectacular aura about
Nothing special a good pressure bleeder or vacuum bleeder (if you have an air compressor) will get the job done in under 30min most of the time.
Old Jan 22, 2017 | 10:59 AM
jim2331's Avatar
jim2331 is infamous around these parts
...I didn't know you could get shop manual cd...how did that work out...I am having hell a time just r/r the main battery on 2010 Speed...JimB
Old Jan 22, 2017 | 09:52 PM
MrVette's Avatar
Shop manual is available on a CD. Check ebay. I suspect it was pirated from Bentley at some point years ago.
PTParks
May 8, 2016 03:49 PM
Coloradocurt
Merchandise For Sale / Wanted
Mar 27, 2016 04:22 PM
