Wiring diagram 2008 Bentley Continental GT Speed
Old Dec 4, 2017 | 10:45 AM
NTXDirect's Avatar
NTXDirect is infamous around these parts
I am trying to find a wiring diagram for a 2008 Bentley Continental GT Speed. I have no power to the air-ride compressor.
Old Dec 4, 2017 | 08:26 PM
Johnny Hotspur GT's Avatar
Administrator
Hope this helps.
Click on screen shots.
ID:	517375   Click image for larger version
ID:	517376   Click image for larger version
ID:	517377   Click image for larger version
ID:	517378   Click image for larger version
Old Jun 9, 2020 | 03:42 PM
Oluwadamilare's Avatar
Oluwadamilare is infamous around these parts
2008 Bentely continental wiring diagram
Hope this helps.
please I need the complete engine wiring diagram of 2008 continental Bentley. The cars hard starts and shoots when throttle to start. The Catalytic converter also flows red.
Old Jun 13, 2020 | 04:01 PM
rich9911's Avatar
rich9911 is infamous around these parts
Go get IETIS. It has all the wiring diagrams. There are a LOT of them!
Old Aug 18, 2020 | 10:03 AM
Plentybad's Avatar
Plentybad is infamous around these parts
I bought IETIS and cannot find the complete vehicle harness assembly to trace anything, any ideas?
Old Aug 18, 2020 | 11:20 AM
rich9911's Avatar
Its there, it's just spread about as lots of diagrams, mainly sorted by function, such as a Can Bus etc.
It's a very complex car and you would never get the entire wiring onto one diagram!
If you can track down the id code for a connector, then you can search for it.
So for example search for accelerator pedal and then select your model. Wiring is different on different years, type and driving side!
Then you'll get a massive list of where the accelerator pedal is mentioned.
So this will take you a diagram like C00511 Engine Management CM Bank 1 and on there you'll see how the accelerator pedal, SAI pressure sensor, Vac pump sensor, Boost sensor, turbo bypass sensor are all connected to the ECU.
Then you'll see X numbers that indicate the connectors and pin numbers and wire colours. So the Boost sensor is part C00654, connector X03446. 3 wires, colours YW,GP, SR.
There's also a list of every connector in the entire body loom, sorted by number of ways.You can click on a connector and you will see the pinout.It won't tell you specifically what each pin does or what you should expect to see on it though.
Yoghurtshotgun
Bentley
35
Mar 9, 2025 03:17 AM
AUTOELECTRIC
Bentley
Mar 10, 2020 07:29 AM
Global Autosports
Bentley Vendor Classifieds
Apr 2, 2012 12:33 PM
RAC
Oct 11, 2010 03:50 PM
