Noise 06 GT
Old Apr 17, 2018 | 09:17 AM
Jonty1951's Avatar
Jonty1951 is infamous around these parts
Noise 06 GT
Getting noise from the drivers side ,sounds like a fan running and appears to be coming from the dash, it will also increase in speed when revving ? it is also intermittent? TIA
Old Apr 17, 2018 | 09:33 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Are you sure it isn't the vacuum pump in the left front wheel arch?
Old Apr 17, 2018 | 09:54 AM
Jonty1951's Avatar
Thanks will check it out
Old Apr 20, 2018 | 10:43 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Check to see if you hear it when you apply the brakes. If so, then definitely the vacuum pump. Just replaced mine with new, but also rebuilt the one I removed. Will keep it for a spare if the motor goes noisy again.
Old Apr 20, 2018 | 02:53 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Brake vacuum pump
Should the brake vacuum pump be inaudible? I can hear mine breathe every now and then, especially when hitting the brakes.THX.
Old Apr 20, 2018 | 03:24 PM
BWings's Avatar
5 Year Member
It is normal to hear the motor running when the vacuum pump runs. The pump consists of a fairly potent electric motor (15 amp circuit) driving an eccentric graphite veined impeller. Both the impeller and the motor get noisier over time. They can get pretty bad (loud), and the graphite impeller blades can become so worn they will eventually let go and can destroy the impeller. But, by that time, the unit will probably be pretty loud and audibly calling out to be replaced.
Old Apr 21, 2018 | 04:48 PM
Kes's Avatar
Kes
Kes is infamous around these parts
I had noise in dash in mine, had to replace circulation pump.
Old Apr 22, 2018 | 10:42 PM
Forster1993's Avatar
Forster1993 is infamous around these parts
Is this the whine I can hear for 10-15 seconds when I first start the car in a morning?
Old Apr 23, 2018 | 11:28 AM
5 Year Member
Possibly air suspension airing up. If not driven daily they lose air over time, also have been known to leak. As stated earlier vacuum pump for the brake assist kicks in. These are all guesses. However you did state it oscillates with engine RPM. That goes back to a fan or something mechanically induced by RPM range.
The best luck
Old Apr 23, 2018 | 03:00 PM
Kes's Avatar
Kes
Upload video, would be easier to find out.
Old Apr 29, 2018 | 01:29 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Yes, it is the vacuum pump.
You can also activate the pump by pressing the brakes a few times to deplete the vacuum in the reservoir.
A word of caution. If the pump runs a lot, then it's a sure sign that the vacuum hose over the gearbox has split. The pump will also eventually get noisier and self destruct.
You can hear the pump better if you open the left side door, it's behind the hinge area in the wheel well.
Fitting a new pump is easy. The hose is an engine out job though.
Old Apr 29, 2018 | 10:16 AM
Johnny Hotspur GT's Avatar
Administrator
Hello ExSF,
Your info is all correct, BUT, the OP stated "it will also increase in speed when revving".... so that in itself is confusing, as the vacuum pump speed would not increase with engine speed.
Maybe Jonty1951 will update us as to the findings.
Old Apr 30, 2018 | 03:19 AM
Jonty1951's Avatar
Mine does make the noise when I keep pressing the brake pedal, but also increases with the revs,now I am wondering if I have two faults?
Old Apr 30, 2018 | 05:34 AM
ExSF's Avatar
Sorry, missed that bit about revs. Not sure what to suggest now but good luck.
Old Apr 30, 2018 | 07:02 AM
5 Year Member
Cycling the brakes will cause the vacuum pump to run. Mine is audible as well if I depress the brakes. From what others have suggested some noise is normal.
WhatI I am not sure about is how often the vacuum pump cycles at idle without depressing the brakes?
