TV tuner replacement.
Old May 2, 2018 | 04:32 PM
steve.2.lowe's Avatar
steve.2.lowe is infamous around these parts
Hi Guys,
Going to replace the TV tuner on my 2004 GT, is it under the parcel shelf cover in the boot (trunk) or behind the left boot (trunk) side panel?
Old Oct 18, 2018 | 06:34 PM
crusher's Avatar
5 Year Member
crusher is infamous around these parts
did you find it?
Old Oct 19, 2018 | 01:06 AM
I did, it's under the parcel shelf in the boot.
Old Oct 19, 2018 | 10:28 AM
crusher's Avatar
5 Year Member
brilliant..what did you replace it with ?
Old Oct 19, 2018 | 10:34 AM
I've replaced the analogue TV tuner (part number 3D0919146) with a second hand digital TV tuner (part number 3D0919148) and not only has that given me digital TV but digital radio too. A change well worth the 30 minutes effort if you can find the part cheap enough. Steps as follows:-
Remove fuse for TV tuner.
Force re scan of Can gateway using VCDS or similar, channel 19, code 0000006 tells the gateway to discover the modules that are available and because you've pulled out the fuse, it will not see this module and think it is not installed.
Drop parcel shelf in boot.
Replace TV tuner (some butchery required of the aerial connectors).
Replace fuse for TV tuner.
Force re scan of Can gateway using VCDS or similar, channel 19, code 0000006 tells the gateway to discover the modules that are available and because you've replace the fuse, it will discover the new module.
Clear any errors using VCDS or similar on channel 57.
Trigger an auto scan via the central console and be patient while auto scan discovers channels!
Re-fix parcel shelf.
Works a treat and now have digital radio via the TV function.
Old Oct 19, 2018 | 11:42 AM
crusher's Avatar
5 Year Member
amazing steve.that sounds just what i need..thanks for the great info and i will start my search for a digital tuner..
i have been looking for a non standard item and wondered if any other vw part is the same..will keep posted and thanks again
Old Jan 23, 2023 | 10:35 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
is this tuner supporting dvb t2?
Boosted
Nov 5, 2003 01:14 AM
sharkster
Oct 30, 2003 12:41 PM
JamE55
Sep 30, 2003 06:22 PM
jro
Aug 5, 2003 10:21 AM
