Parking sensors replacement
Old Aug 26, 2018 | 11:13 AM
Mark Johns's Avatar
Mark Johns is infamous around these parts
Hi , Hope some one can advise?
require 4 or 5 pd c sensors to be replaced. Two types on the car ,apparently central ones around number played and parking light different to rear side bumper sensors. Assuming bumper will require removal to replace sensors may as well replace the few remaining that work. Have been quoted £59-£79 per sensor before painting and assume these sensors should be found on other VW , Skoda marques at a lesser price.
Anyone confirm which sensors would fit / be suitable rather than paying astronomical prices.
The cars an 04 gt continental.
Any advice information much appreciatec😀
Old Aug 26, 2018 | 01:32 PM
Lucky John's Avatar
Lucky John is infamous around these parts
First a couple caveats-I've never replaced these and don't know anything about them-I'm only trying to help.
The link to Scuderia should be
Scuderia Link
https://www.scuderiacarparts.com/par...37224?h=110719
This tells us you need two of each type on the rear bumper and two of the elbow style on the front and four wired ones for the front.
They are part numbers 3D0919275E and 3D0919275D.
The
se are readily available on ebay both US and UK and even Amazon for about twenty us dollars or less. If you really want to pinch some pennies you can order ten from Alibaba at $8 dollars a piece...
https://antauto.en.alibaba.com/produ...0919275E.html#!
The Bentley part numbers are the same as the VW, and Audi so they should work. The painted caps look like they could be reused so I am not sure why you would need new ones and be paying to have new ones painted but again I have never done anything with these. Hope this helps. Sorry about the font changes but I am not going into the HTML and trying figure out where the cut and pastes are changing it.
Good Luck, John
z4met
Aug 14, 2009 07:55 PM
996c4s
Nov 1, 2006 11:14 AM
