2006 Continental scuffle panel/cowl removal
Old Nov 29, 2018 | 07:54 PM
Mishanya's Avatar
Mishanya is infamous around these parts
Hi everyone! New to the forum.
Could you, please, give some instructions on how to remove scuffle panel/cowl in order to clean under it (leaves etc) on my 2006 Continental?
Thanks very much!
Old Nov 30, 2018 | 01:08 AM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
Sit in the car turn on the ignition and go into the screen and place the wipers in “ service “ mode .
Turn it off ,
With a socket remove the wiper bolt and carefully wiggle the whole wiper blade off .Before this with a bit of tape mark the position on the screen to aid reassembly ,
once the wipers are off theres a coulple of small self tapper screws at the far corners holding the edges , they need loosening .Then twist the lock/ catches open and lift off the panal,
I use an adapter on the end of the Hoover ,down to 15 mm curved copper pipe about 12 inches long to poke about in places too small for my hand .The key place is under the middle heating / ventilation intake situated in the middle .
Thats where the drains are .
Normally in other cars drains are near / under the hood hinges at the corners , not so with early Bentley GT ,s hence the issues of potentially wet wiring looms.
I also made a custom plastic cover for the various wire/ plugs that sit on top of the fuse box to protect from water .
That box is tucked under the scuttle on the passenger side ,the wiring looks vulnerable as it is so mines now protected from water drips .Theres a lot of sensitive connections there .They look like sitting ducks for water ingress .
When you have finished with that end, “ do “ the other end ,
With some strimmer line poke out the corner of the fuel filler to unblock that .
Poke up the two drains under the trunk rear edge .These two start from under the rear spoiler .Lift the spoiler and try and poke the drains or blast air from the gutter that the spoiler sits in .Test patency with a cup of water etc .
Theres a couple of air con drains accessed from inside the car .
Theses are either side of the centre console behind the carpet and sound proofing rubber elbows that you can pull off and poke a pipe cleaner up .
#hit accumulation happens in the condensation pan under the HVAC system .If that happens water gets unto places it shouldn’t like the 2nd fuse / relay box under the passenger foot well .In this box is the KESSY system .
If the stater motor won,t turn off ( damp box in the foorweel ) then it’s an engine out jobbie for a new stater motor .
All just regular preventive maintenance.These cars are not park and forget , they are hands on .
More here with pics
https://www.6speedonline.com/forums/...ter-drain.html
Old Nov 30, 2018 | 03:33 AM
Mishanya's Avatar
I greatly appreciate it!
Old Dec 8, 2018 | 08:14 PM
Mishanya's Avatar
Found a couple of items on Amazon.
Helped me great deal to clean.
Amazon Amazon
Amazon Amazon
Old Dec 13, 2018 | 08:33 AM
onetimeonly's Avatar
onetimeonly is infamous around these parts
it says I need to have 5 posts in order to access the sites features. and I need to send a private message to someone.
twrblue
Sep 13, 2017 04:21 PM
Lotus Man
Mar 15, 2016 08:32 PM
Silverbullet911
Jan 24, 2014 03:00 PM
