New noise after engine pulled out
Old Oct 2, 2019 | 02:06 PM
British's Avatar
Gone, But Not Forgotten.
British has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud of
Just finished an enormous amount of work that included pulling the engine to get at all the parts I wanted replaced (o2 sensors, vacuum lines) and the part I needed replaced (turbo solenoid).
They delivered the car to me on flatbed (very nice of them) and I took it for a quick spin before I garaged it and within a block, I noticed a new noise that sounded a lot like a wheel bearing going bad from my left front wheel area. It howls (too strong a term, it's not loud at all) and changes pitch the faster I drive and does not occur when still.
It's pretty unlikely it's really a wheel bearing, since they were fine before it went into the shop. I'm suspecting a CV joint or half-shaft problem. It's possible that something is just rubbing and it's not mechanical at all.
But pulling the engine and bolting it back in, I can envision something going wrong with the transmission-to-wheel mechanisms.
Anyone have any clue?
I'm taking it back to get it checked, but I would like to be conversant with what it could be. I've looked at the exploded diagram of the CV and half-shaft, I didn't see anything obvious that could be installed incorrectly.
Old Oct 2, 2019 | 02:35 PM
Rico.Adams's Avatar
5 Year Member
Rico.Adams is infamous around these parts
Its a million dollar question, engine was out with all the other bits that go with it, as you say no noise when stationary, If you can take a video lets listen to this sound maybe I or someone can identify the problem. Good idea after spending a sum take it back go for a drive with them ...
Old Oct 2, 2019 | 03:52 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Indeed good advice. Glad it worked out. Important test at this point is to do a third gear 2000 RPM hard acceleration. Then have them check codes. This would reveal any turbo charger deviations + or -, overboost, underboost or limp mode. There should be a tremendous surge of power doing this a couple of times.
This has nothing to do with the strange sound we're waiting for the video. My suggestion is so you don't end up discovering later that it isn't boosting properly. They will than tell you it's not their fault.
Old Oct 3, 2019 | 05:40 PM
British's Avatar
Looks like it is a wheel bearing. It sounded exactly like a wheel bearing, but I knew there was no way a wheel bearing would coincidentally go bad after an engine-out. Well, on the lift, wiggle wiggle.
New wheel bearing next week.
Old Oct 4, 2019 | 01:04 AM
Rico.Adams's Avatar
5 Year Member
Now you know, at least its nothing to do with the engine or transmission, you know as you can hear it, no matter what we think we cant hear the sound ...
krikra
Dec 5, 2016 04:49 PM
rdprice
Mar 2, 2015 04:48 PM
Nrick70
Bentley
Feb 27, 2015 01:35 PM
aagau
May 30, 2011 10:55 PM
Hedonistic
Aug 2, 2009 05:39 PM
