05 Bentley CGT - Location of the TV Tuner 3D0919146
Old Mar 26, 2020 | 04:16 PM
Littlj01's Avatar
Littlj01 is infamous around these parts
You're right my bad.
Old Mar 27, 2020 | 12:39 AM
Littlj01's Avatar
I hardware version I bought was a Digital TV Tuner from a VW Phaeton 2008 P/N: 3D0919148 and is a direct replacement of the analogue P/N: 3D0919146 apart from the antenna connectors 4x which need to be taken from their connector housing which in my case did not fit the newer Phaeton unit.
Last edited by Johnny Hotspur GT; May 22, 2021 at 05:10 AM. Reason: Correct the original part number
Old Mar 29, 2020 | 07:19 PM
H-M3's Avatar
H-M3 is infamous around these parts
Well done mate , gives us some hope but this dtv is needle in haystack.
Old Oct 5, 2020 | 03:56 PM
molphar's Avatar
molphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud of
A bit offtopic, but close to subj. How can i connect to TV tuner AV in? what pins i need to use? maybe some one did it?
as i could find this is an answer
Front S Video via pins 49,50,51
Rear S Video via pins 42,43,44
Front Composite video via pin 52,53
Rear Composite video via pin 45,46
Front audio via pins 47,48,49
Rear audio via pins 41,42,43
OR you can order ready wire from ebay and dont mind with pins -
ZLA-MFD1 adapter, you can easyly google it ))
Old Oct 11, 2020 | 12:52 PM
molphar's Avatar
crap. it is not working proprtly. i have sound, but video is b/w, and, there were some wires in that pins, and i don''t understand. mayvbe av in was already done somewere in cockpit? and one more strange thing. sound is working for av1 and av2 on same pins.
Old Apr 17, 2021 | 08:43 AM
Neil Jenkins's Avatar
Neil Jenkins is infamous around these parts
Digital tuner
Hello,
I have replaced the tv tuner with 3D0919148.
plugged brown, green and black plug in. Not getting dab or any channels. I also selected england/ Ireland.
Any suggestions
Old Apr 17, 2021 | 08:49 AM
Digital receiver
Originally Posted by Littlj01
Johnny, just wanted to update you on the TV tuner install. Did it last night. Disconnected the old unit. Antenna connectors do not fit the Phaeton unit, so I removed them by lifting off the pint connector cover and then lifting up the retaining clip on the connector and the antenna cables just pull out. Making sure number 1 went into the far right slot of each pair i pushed the antenna connectors into place. Unit fired up straight away I changed the country location in the setup to England / Ireland and was away with digital TV and DAB radio.
So no need to re-scan the CAN etc. It was plug and play. Next upgrade to fit today is an upgrade of the Bluetooth module. Found a module in the US for $100. Thanks for all your help.
Hello
I have completed the above. But not working. All cables are in and fan working on unit.
No dab Radio or Tv 🤔
Any suggestions?
Old Apr 18, 2021 | 12:42 AM
Dark Green's Avatar
5 Year Member
Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !
Assuming that you live in a good DAB / DTV area, which even now many areas of the UK aren't, have you tried a complete power down and reset of the whole car? By that I mean both batteries off iaw correct procedure, and then leave for at least half an hour for any capacitors to discharge.
The unit is fan is probably running because the receiver has a permanent power feed, and has recognised a wake up signal on the bus.
Old Apr 21, 2021 | 04:34 PM
sspeeder's Avatar
sspeeder is infamous around these parts
A few months back I also upgraded my old analogue TV tuner for the newer digital/hybrid module 3D0919148. This turned out to be unsuccessful since I could never got it to work (just white noise on the screen). After much fiddling with coding and adaption of the module and with the help of the ever present Johnny (thanks again Johnny) we came to the conclusion that this module only works on DTV MPEG2 signal whereas in my country the DTV runs on the newer MPEG4 signal. I'm afraid this makes this module upgrade useless. This may be your case if in your country you also have MPEG4 signal and no analogue TV stations anymore. The module is a hybrid model meaning it tunes in both analogue and digital signals but in our case there aren't any more analogue stations available and no MPEG2 signal on the DTV stations. In conclusion I just have a brick hanging under the rear shelf back there in the boot.
Old Apr 21, 2021 | 05:35 PM
Johnny Hotspur GT's Avatar
Administrator
Hello @sspeeder ,
But you could install the pins/rca jacks for video/audio inputs 1&2, and use it like a home stereo receiver, and one of those inputs could be a TV tuner like this below, or and video audio input you choose to display on the screen and sound system.
https://www.ebay.com/itm/Digital-tv-....m46890.l49286
Johnny
Old Apr 22, 2021 | 03:38 PM
kongolo's Avatar
5 Year Member
kongolo is infamous around these parts
Where is it located on a convertible?
Old Apr 23, 2021 | 09:11 AM
sspeeder's Avatar
Hi Johnny
Thanks for the info. That is indeed a viable solution.
it is only a pity we can't use the car headunit to scroll through the channels of that DVT tuner as we do in the original setup.
Old Apr 23, 2021 | 05:08 PM
molphar's Avatar
Location of tuner in cabrio. i think there are 2 ways of accesing it
Old Apr 23, 2021 | 05:20 PM
molphar's Avatar
Hello @sspeeder ,
Johnny
Can i ask You what are pins for av-2 for 146 and for 148 tuners, as far as i know they are a bit different. for testing purposes i use direct connection to tuner(as on the photo), but for apple tv i use 12pin connector near ignishion acu.
AV-1
firs pin with wire is 47
Old May 22, 2021 | 05:33 AM
Administrator
Originally Posted by Neil Jenkins
Hello,
Any suggestions
Hello @Neil Jenkins ,
We're you ever able to get the unit working, what is your location ?
Johnny
