rear seat storage on 05 GT
Old Aug 8, 2020 | 12:42 PM
gogolchris's Avatar
gogolchris is infamous around these parts
My dog broke the sliding wooden storage between the rear seats. I have removed the segments from the backing. Does anyone know how to put it back together?
Old Aug 10, 2020 | 03:26 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Yes, it can be done. Each panel slides in a track. All panels are mounted on a fabric mesh backing. You will probably have to replace this fabric. Each segment is glued individually to the fabric. You should remove the rear console, but if that is too much work, simply lift the rear of the center panel and you can reach through. I believe each of the panels is numbered on the back. This is a very FIDDLY job. Be patient. There is a magnet at the front of the sliding track that traps the sliding panels at the front.
shabs
Bentley
11
Sep 20, 2017 11:09 AM
xza8
Bentley
May 4, 2014 05:28 PM
trisgale
Jul 17, 2011 07:11 PM
ritchieswimwear
Nov 9, 2006 09:03 AM
