Brake hoses
Old Apr 24, 2021 | 08:00 PM
H-M3's Avatar
H-M3 is infamous around these parts
Brake hoses
Hi guys planing on maintenance work on the car. Does anyone have the part numbers for the brake hoses that Bentley recommend changing every so often? Also what is the correct brake fluid on these cars?
Old Apr 25, 2021 | 02:49 AM
Dark Green's Avatar
5 Year Member
Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !
The fronts from body to caliper are 3W0611701 but seem to be NLA.
The rears are 3D0611775G (Qty 3) and 3D0611775H (Qty 1) which seem to be available but in short supply.
Old Apr 25, 2021 | 08:41 PM
H-M3's Avatar
thanks DG, I thing some of these part numbers have superseded to newer part numbers. Is that all the parts that is needed? Also the first one you quoted, do I need one of those? Plus is it standard Dot 4 brake fluid?
thanks again
Old Apr 26, 2021 | 12:26 AM
Dark Green's Avatar
5 Year Member
You'll obviously need one of the front hoses per calliper.
Sorry, have also realised that there's a third pipe at the rear 3W0611775A Qty 2.
Flying Spares sell a kit containing all the hoses, but personally I would replace them all with braided rather than rubber.
The factory recommend DOT4 fluid.
Old Apr 27, 2021 | 06:02 PM
H-M3's Avatar
Thanks DG I ended up ordering the kit from them. Just need to order some dot4 now. Thanks
Wealth Manager
Jul 12, 2015 09:48 PM
DNugget991GT3
Aug 5, 2008 03:38 AM
johnnytaboo
May 18, 2008 07:06 PM
Nov 4, 2006 10:37 PM
