Another day, another Engine pull
Old Jul 15, 2021 | 04:05 PM
Johnny Hotspur GT's Avatar
Administrator
Hello @Zaos ,
Not to pour salt in the wound, but I have to ask what happened to cause a second drop of the drive train, as I had asked back in 2017 in your pulled my engine thread if you had taken care of the plastic lines at the back of the engine itself, but I never saw a response, I sincerely hope that was not the issue now..
Johnny
Old Jul 15, 2021 | 04:13 PM
Zaos's Avatar
Zaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond repute
Thanks, very good info. The problem was into the chassis part, not as usually, the engine side. Ill post the pictures of my demise....LoL.
Old Jul 16, 2021 | 11:19 AM
Zaos's Avatar
Yeah, I removed all plastic lines and they are holding just perfectly see picture below: I replaced the plastic lines with metal brake lines
No leaks here. If this was leaking I would not been a happy camper....
But here is the leak!! Looks like I tightened the hose clamp little too much and the rubber sheared over time. Here too you can see plastic is replaced with metal lines and tees
Here, you can really see the value of having a smoke tester..
Arrow shows clearly the rubber sheared here below the steering rack. Only way was to pull the engine again All labor and less than 25 cents worth of parts. Maybe I'll create a longer rubber line to give it more flexibility
Old Jul 16, 2021 | 12:34 PM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
Perhaps some different clamp styles as well? Jubilee clips are not the best
C
Old Jul 16, 2021 | 01:45 PM
Administrator
C
I agree, I used the factory style clamps, the worm screw type is very thin and does cut into the rubber hose.
Johnny
Old Jul 16, 2021 | 02:08 PM
CatmanV2's Avatar
5 Year Member
Oetiker I *think* they're called?
But I *very* much sympathise!
C
Old Jul 17, 2021 | 11:39 AM
Zaos's Avatar
Dunno if I agree,
I would say a severe shear like this is more that just solving it with an Oetiker style clamp (thin or not). Never was a fan of them anyways, since they only provide 1x use and difficult to remove (because only due to low cost to manufacturer and quick to install). I could just as easily over clamp them as anything else. Thinking the hose did not have enough flexibility being too short, likely when remounting engine and deteriorating over time. Remember, I went from plastic to metal lines. This changes a lot! since they are much harder than the plastic ones. A metal line, could easily cut the rubber, after vibrating over time as lines flexes. This particular line connects directly from the chassis to the engine, unlike the others.
None of the other clamps, showing nothing and seems solid.
Loosely Goosely seems like the path I am going at the moment. I am all ears to hear from you, since, I am not about to pull my engine 3x....lol
~ZaOs~
Old Jul 18, 2021 | 01:21 PM
Administrator
Hello @Zaos ,
I see it as the one time use Oetiker clamps will only clamp to a certain clamping force when the proper tool is used to install them, whereas the worm type that you have used will not stop at the correct tightness, which can and have been overtightened, I have done it myself in the past, then the thin band cuts into the hose.
It also appears to me that some of your clamps may be to tight, like in your picture attached below.
Just my observation 😀
Johnny
Old Jul 18, 2021 | 01:36 PM
Zaos's Avatar
Hello @Zaos ,
Johnny
Yeah, I can see this and definitely a point on over forcing. I am Going to to some further inspections and pull tests on how mine are fairing, before engine goes back in. I just like them tight
Old Jul 18, 2021 | 01:43 PM
Zaos's Avatar
Originally Posted by Dark Green
I'm intrigued by this because I've got my engine out at the moment, to change the transmission, and am going to replace all the vacuum hoses whilst I'm at it.
What you haven't mentioned is changing all six vacuum solenoids whilst you're doing everything else.
I appreciate that one has to stop somewhere, but for the price it seems a no brainer to do them.
Something that was recommended to me was to change the O2 sensors, while engine out. Another recommendation was to change the starter, but I never did. O2 sensors were easy/inexpensive and plenty of non Bentley part### working
Old Jul 18, 2021 | 02:07 PM
Zaos's Avatar
@Johnny Hotspur GT You could not be more correct. I totally over tightened my vacuum lines, causing their failure. Wish I learned earlier, but they always worked. However, if I weren't such a tight A$$ like I am, it would be fine. I am still not a fan of the Oetiker clamps, but learned not to screw them too much .......
Definitely making me a tight A$$
Old Jul 18, 2021 | 02:11 PM
Zaos's Avatar
If you don't want to resell, this is all good. You have to reprogram the ECU for O2, ...or other deletes
Old Aug 15, 2021 | 04:50 PM
Administrator
Any updates @Zaos ?
Hope all is well !
Johnny
Old Aug 16, 2021 | 09:57 AM
Zaos's Avatar
Spent the weekend finally putting it together. Had some issues with the exhaust studs shearing, so I had to buy an acetylene torch and knock them out. I took my time being much more rewarding doing it slowly.
Only got the wheel arches to put back on and hopefully all works. Pulling a w12 Bentley engine, is probably one of the most difficult engines ever had to pull lol....
Old Aug 16, 2021 | 11:49 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Hi Zaos,
How much hight have you under the car fully lifted. I haven't bought a lift as my roof is only 9ft high. Can you stand or crouch under the car?
