Head Unit Coding
Old Oct 29, 2021 | 04:57 AM
DrGigabit's Avatar
DrGigabit is infamous around these parts
Head Unit Coding
Hello,
I have the following errors coming out of the head unit
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008
Component: ZAB COCKPIT 0223
Coding: 0000000
Shop #: WSC 12345 123 55096
VCID: 6ADB77AF467FE0DB7D-5178
9 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
01308 - Control Module for Roof Electronics (J528)
004 - No Signal/Communication - Intermittent
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
00466 - Control Module for Steering Column Electronics (J527)
00857 - CD Changer Unit (R41)
003 - Mechanical Failure - Intermittent
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
01320 - Control Module for Climatronic (J255)
01334 - Door Control Module; Rear Right (J389)
Obviously, the HU is coded incorrectly. Does anyone has a correct coding? I tried to calculate the code, based on the installed components (Navi, TPMS, CD-Charger, Phone), but it did not accept any of the combinations.
I assume, the other errors are the result of the wrong coding.
Here is what I have in VCDS interface.
Old Oct 29, 2021 | 06:10 AM
Samhain's Avatar
Samhain is infamous around these parts
I don't think you need to code the ZAB to the car. When mine was replaced I think it was just plug and play.
Old Oct 29, 2021 | 06:14 AM
DrGigabit's Avatar
This error message suggests otherwise
Old Jan 22, 2022 | 02:57 PM
molphar's Avatar
molphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud of
got same issue when updated to later headunit
Old Jan 22, 2022 | 05:54 PM
molphar's Avatar
Ive got idea ))))) ill try to use another dash and i thing it will help to code headunit. it has another gateway. and ill try to use one dash and anothe gatewy lol
UPD - failed)
nothing wil stop me from getting what i want
UPD. zero result. Power of two modules goes throught dashboard, so it is impossible to connect gateway from another cluster. i'm so annoyed that there is no one who can ,ake adaptation. even oficial service in my country
And ofcource no adaptation for heaunit. maybe headunit is an issue itself?
Littlj01
Bentley
42
Apr 19, 2022 03:52 PM
TurboDelaney
Cayenne 955/957
Jan 22, 2011 03:05 PM
Arnie
Jul 13, 2004 08:12 AM
