2009 Bentley Arnage R, ABS login and coding value
Old Nov 8, 2021 | 09:51 PM
phsarkiri's Avatar
phsarkiri is infamous around these parts
Question 2009 Bentley Arnage R, ABS login and coding value
Hello everybody!
Can you help me to generate log in and coding value for ABS Brakes please?
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.1.0
Data version: 20200331 DS317.0
www.Ross-Tech.com
Dealer/Shop Name: AK
Workshop Code: 935 00200 000000
VIN: SCBLC47J89CX14211 License Plate:
Mileage: 6364.4 miles Repair Order:
Chassis Type: 7J (3Z - Bentley Arnage (2007 > 2010))
Scan: 01 02 03 15 19 47 56 65 77
Address 01: Engine Labels: None
Part No SW: 3Z4 906 018 M HW: PB1 156 09P A
Component: ME711ST10 LEV2R G 09J4
Revision: --H03--- Serial number: VWZ1Z0H2984448
Shop #: WSC 00000 000 00000
VCID: 46834D1932607CB671-5140
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: None
Part No SW: 3Z0 907 044 HW: GS1 911 1
Component: ZWIC2830 6.75 RdW 2830
Revision: 00000001 Serial number: 0012878
Coding: 0001111
Shop #: WSC 56476 002 1048576
VCID: 75E1FAD51F06A72E28-5124
Address 03: ABS Brakes Labels: None
Part No: 3Z0 614 511
Component: ESP 5.7 rear H00 0004
Coding: 0000000
VCID: 6FEDC8BD7D5A9DFEE2-5124
2 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
01044 - Control Module Incorrectly Coded
000 - -
Address 15: Airbags Labels: None
Part No SW: 3Z7 909 601 HW: 3Z7 909 601
Component: 01 Airbag 9.42 H09 0060
Revision: 92H09006 Serial number: 003000002AS0
Coding: 0012337
Shop #: WSC 102605 770 685539
VCID: 7DF1E2F52436FF6E60-8028
Subsystem 1 - Part No: 3Z5 959 339
Component: BF-Gewichtsens. H02 0004
Subsystem 2 - Serial number: 01ECT
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63300RB4 Eÿ†63
Subsystem 5 - Serial number: Eÿ†63400RB4 Fÿ†63
Subsystem 6 - Serial number: Fÿ†63500RB4 Gÿ†63
Subsystem 7 - Serial number: Gÿ†63600RB4 Hÿ†63
Subsystem 8 - Serial number: Hÿ†63700RB4 Iÿ†63
Subsystem 9 - Serial number: Iÿ†638 RB4 9ÿ
Subsystem 10 - Serial number: 9ÿ
Address 19: CAN Gateway Labels: None
Part No HW: HW1 03
Revision: 11001001 Serial number: 00000000000282
VCID: 55A19A55FFC6C72E08-5140
Subsystem 13 - Part No: 3Z0 909 901 A
Component: CAN LS Gateway 0201
Shop #: WSC 12336 024 394758
Address 47: Sound System Labels:
VCID: 55A19A55ACC6C72E08-5140
Note: Excessive Comm Errors
Address 65: Tire Pressure Labels: Redir Fail!
Part No: 3W7 907 273
Component: Reifendruckueberw. 0003
Coding: 0070711
Shop #: WSC 00070 000 00000
VCID: 7DF1E2F52736FF6E60-5140
2 Faults Found:
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
004 - No Signal/Communication
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Address 77: Telephone Labels: None
Part No SW: PM1 144 36P A HW: PM1 144 36P A
Component: UHV Premium rSAP 0020
Coding: 0000256
VCID: 61C9BE85BB8E3B8E64-5140
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
End---------------------(Elapsed Time: 02:50, udsna)-----------------------
ET911
Feb 13, 2021 07:48 PM
BartN (TX)
Feb 15, 2010 09:22 PM
Almo
Nov 23, 2009 11:28 AM
Broadway Performance
NY Tri State
Mar 4, 2009 05:05 PM
vramani
Southwest
14
Jan 16, 2009 11:23 AM
