Force inflating Bentley GT Struts?
Old Dec 11, 2021 | 09:30 AM
Copperline's Avatar
Copperline is infamous around these parts
2006 Bentley GT
Does anyone know where on VCDS can you inflate the struts?
I have gone through every part of 34 Level Control and I can not figure out how to activate the compressor for the front struts. I replaced them and now the front of the car is nearly on the ground. "Jack Mode" is activated and I cant get it to go away so I was told I needed to "force" the front struts to inflate and then do the adaptation from there. Coding on my car is 0005561 which also seems wrong but whenever I try to change it to what should be correct (or anything different) I get an "out of range" error.
Adaptation in its current condition just gives me errors and the front never inflates.
On the 34 - Level Control output tests there is "Vehicle Is Being Leveled" (which sometimes activates the compressor and raises the rear), Then "Front Left Being Lowered", Then Front Right Being Lowered", then it just cycles back around. I never see front being raised or anything related to the rear.
I know that my compressor works because when I start to do the adaptation process the compressor runs and the rear goes up but nothing ever happens to the front. I also show 5.6 Bar in the accumulator, I have checked the wheel sensors and they are registering. No clue why I cant get the front to do anything.
Any help would be immensely appreciated. I am 9 months into this rebuild and this is the last step before getting the car back on the road.
Simonbaz
Bentley
Nov 12, 2020 11:12 AM
therron4ou
Bentley
Apr 8, 2019 02:46 AM
Hawkinz69
Bentley
34
Jun 9, 2018 10:27 AM
cskouge38
Bentley
Nov 27, 2017 11:31 AM
paulcr
Dec 21, 2015 02:29 AM
