Low Dust Brake Pads?
Any recommendations / links to brake pads that generate less dust than the OEM pads?
There are several versions available for my Porsche including Akebono and Metal Masters.
Any for my 2009 CGT?
Thanks.
Thanks.
I have recently changed my pads and rotors and used PAGID WHITE for the front (Jurid 571872JC)
https://www.autodoc.co.uk/jurid/7864152
and for the rear I used EBC Red Stuff (DP31470C)
https://www.ebay.co.uk/itm/301788176...YAAOSwm6dhoDCz
The front pads from PAGID are recommended for our Bentleys but they are indeed a bit narrower than the OEM ones, 73.5 mm / 79 mm. Nevertheless I had no problem in fitting them.
EBC also makes a Red Stuff pad for the front, same size as PAGID's,
Both front and rear pads are made of ceramic/aramid compounds and I am quite pleased both for their silent stopping power and dust production reduction. My alloys stay cleaner for longer than before and this was my initial goal.
Very good info sir - much thanks!
