Overheating problem Bentley GT
Old May 2, 2022 | 03:04 PM
Shaqovic's Avatar
5 Year Member
Shaqovic is infamous around these parts
Hi there,
again I am in need for a help from this great forum members, I own a Bentley GT 2005 and noticed it started to overheat twice at least during a 20 miles drive, the fan immediately kicks in when it passes normal temperature and brings it back to normal.
picture attached to what point the arrow goes
Old Jan 27, 2023 | 01:34 PM
Owner bentley's Avatar
Owner bentley is infamous around these parts
Iam have the same issue , did you get the solution?
Old Jan 27, 2023 | 03:57 PM
Shaqovic's Avatar
5 Year Member
The problem was solved with replacing water pump and thermostat.
Regards.
Old Jan 29, 2023 | 04:24 PM
Regards.
electric water pump or mechanism one ?
thermostats is 106c ?
Old Feb 1, 2023 | 12:40 PM
MrVette's Avatar
MrVette is infamous around these parts
I'm confused. The temp gauge doesn't show it is overheating but the parking brake warning alarm is on.
I have occasionally gotten that parking brake alarm but the problem has always fixed itself. Intermittent only.
Old Feb 5, 2023 | 01:41 PM
hello dear ,
I have also parking brake issue and warning at the dash
and OVERHEATING !! But when the fans works at full speed the temp go’s back to normal .
any idea?
2chainz
Bentley
Dec 24, 2021 12:22 PM
hueyy702
Bentley
Nov 16, 2016 09:59 AM
onempty
Bentley
Jan 13, 2015 01:49 PM
